Latest post Thu, Aug 30 2018 7:49 AM by mkj. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Aug 28 2018 4:59 PM
    • sonysharp
    • Joined on Tue, Aug 28 2018
    • Posts 1
    • Points 45
    more core vs more speed
    Hi dear MC users. I'm just starting to learn AVID MC and I need help. if it's not hard for you, advise me which option is better for editing in Avid MC in 4k: macbook pro with 16Gb Ram and 6-core 2,2 GHz i7 or iMac Quad-Core i7 3,6 GHz with 16Gb Ram ?
    Filed under: , , ,
  • Tue, Aug 28 2018 9:27 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,321
    • Points 53,415
    Re: more core vs more speed
    I believe higher clock speed benefits NLE over core count.
    Using MC 8.4. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
  • Wed, Aug 29 2018 2:27 AM In reply to
    I think more cores have better long term value.
  • Wed, Aug 29 2018 8:05 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 537
    • Points 6,845
    I would look at this article, which attempts to break down how Media Composer uses computer hardware.
    http://www.avidblogs.com/how-avid-media-composer-uses-a-computer/
    HP Z800, HP8760, SonnetFusion RAID, Mojo DX, Symphony 8.10, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Wed, Aug 29 2018 9:02 AM In reply to
    As long as you have "enough" cores then speed over quantity every time for MC.
    Its not the same for all NLE systems but certainly its been the case with MC for many years.
    As core count goes up the max CPU speed tends to lower. For many MC functions splitting the task over many cores is less efficient than hammerimg a limited number of cores.SO its hogh CPU GHz for me. But it has to be quad core or more.
    A dozen cores is good 24 is a waste
  • Thu, Aug 30 2018 1:33 AM In reply to
    • cls105
    • los angeles
    • Posts 374
    • Points 4,890
    fact: rendering in avid is much slower than it should be.  This really needs to be improved.
    They qualify these high end pc's and at the end of the day, Media Composer does not use this hardware efficiently when rendering.
    Transcoding and ama export, is another story. I give them an a+ for that, although there should be a web quality version at the ama export speed.
    I don't think there is one machine for all uses.  If you want a transcoding station, get as many cores as possible.  If you want an every day editor thats rendering often, you want a higher clockspeed since multicore use is dismal on MOST fx with rendering.
    And if youre working on long form, a 14 core, will export the timeline 2 times faster, that a 6 core (compensating clock speed) exporting really does use all of the cores.  Same with transcoding, double the speed.
    MC 2018.12, diy x299 7940x, 1080ti, 128gb ram, w10 pro (1803) [view my complete system specs]
  • Thu, Aug 30 2018 2:20 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 218
    • Points 2,290
    Defiantly the imac
    i had a 2014 quad core 2.7 ghz mackbook Pro i7 and a 2015 imac about 4.0 or so ghz before and now I have a 4.2 ghz 2017 imac with 8gb Gfx card and 40 gb ram and it is sooo much better. Everything is so much faster.
    i do a lot of long form , over an hour ,often cuts are 2 hours when rough and getting them out for preview needs to be efficient.
    i can get h264 renders at 133 fps using third party encoders.
    Recently I did a job with split screen (40 min) where I used resizes luma keys ani matt keys colour correction etc,all stacked up and it would play without needing to render.
    The other issue is having a big screen.
  • Thu, Aug 30 2018 6:42 AM In reply to
    • cls105
    • los angeles
    • Posts 374
    • Points 4,890
    its also worth mentioning that from last year, intel's consumer cpu's went from 4 to 6 to 8 cores (next month) (thanks to amd).
    My hope is that all developers starting making use of this mainstream tech *cough* mc rendering.
  • Thu, Aug 30 2018 7:49 AM In reply to
    • mkj
    • Sweden
    • Posts 387
    • Points 5,135
    must say that HP z240 with Intel i7 7700K 4,2 ghz is much bang for bucks!
    for example; exporting a 44 min sequence to MXF, dnxHD120 in 15 mins! (with AMA File export)
    44 mins MXF to h264 in Adobe Media Encoder, 12 mins..
