Latest post Fri, Aug 24 2018 12:45 PM by SwissGarry. 0 replies.
Page 1 of 1 (1 items)
  • Fri, Aug 24 2018 12:45 PM
    • SwissGarry
    • Joined on Thu, Mar 15 2018
    • Posts 1
    • Points 5
    HELP - Assertion Failed trying to open Tool Palette
    Hi all, we are having a continued error message, related to the attempted opening of the tool palette, from both the source/record monitor, and the settings list in the project window. This only occurs when logging in through network account. Please see below.
    System setup:
    MC 2018.5.1 on Sierra 10.12.6
      Model Name:    Mac Pro
      Model Identifier:    MacPro6,1
      Processor Name:    6-Core Intel Xeon E5
      Processor Speed:    3.5 GHz
      Number of Processors:    1
      Total Number of Cores:    6
      L2 Cache (per Core):    256 KB
      L3 Cache:    12 MB
      Memory:    32 GB
      Boot ROM Version:    MP61.0124.B00
      SMC Version (system):    2.20f18
      Illumination Version:    1.4a6
    As previously mentioned, we use network log ins, which uses the local student profile for it's settings. Both the local admin and student, do not show this error when opening the tool palette, furthermore, if one logs in on a network account, opens MC using the network user prfile, error, then imports the student user profile, the error will not appear and the tool palette behaves as expected, switch back to the newly created network users profile, the error has gone too and the palette works. We can also duplicate the tool palette in the settings and activate it, then delete the original, and it works on the network user profile. We have tried deleting numerous settins files, to no success. Any ideas?
    The work around is fine for me, but we have many client machines used by students, and for it to work as it should will save me far more time in the future.
    Error report:
    AVID SYSTEM DUMP - Fri Aug 24 12:57:39 2018
    Assertion failed: m_toolPaletteWindow
    [/Snapshots/relengmini4_1527802737/ppg/MediaComposer/Media_Composer/ToolPaletteSetting.cpp:291]
    ________ PClass Registry _______________________________________________
    Table size:             72 bytes
    Registered classes:     284
    Unknowns encountered:   1
          Class-Name       PCID  Version Version-Read  Minor-version-extensions &
                                 Written   Min   Max   Attributes supported
                  omf2TIFD tifd     0       0     0    NO_EXTENSIONS
      WorkspaceLinkageSetting WLst     1       1     1    NO_EXTENSIONS
                   A23Node A23n     1       1     1    NO_EXTENSIONS
            WAVEDescriptor WAVE     1       1     1    NO_EXTENSIONS
        TabDecorationState Tabs     1       1     1    NO_EXTENSIONS
                   A23Tree A23t     1       1     1    NO_EXTENSIONS
          ATrimModeSetting TMst     5       1     5    NO_EXTENSIONS
                 ATimeWarp WARP     2       1     2    NO_EXTENSIONS
           AGeneralSetting GENS    10       1    10    NO_EXTENSIONS
                  omf2JPED jped     0       0     0    NO_EXTENSIONS
                  omf2MSLT mslt     0       0     0    NO_EXTENSIONS
       MPEGAudioDescriptor MPGA     1       1     1    NO_EXTENSIONS
            Timeline Notes TNOT     1       1     1    NO_EXTENSIONS
           ANagraMediaDesc MDNG     1       1     1    NO_EXTENSIONS
            MPGIDescriptor MPGI     1       1     1    NO_EXTENSIONS
            AFileMediaDesc MDFL     3       1     3    PCLASS_EXTENSIONS1( PCLASS_EXT(64BitSupport, 1) )
           AVideoMediaDesc MDVI     3       1     3    NO_EXTENSIONS
            AFilmMediaDesc MDFM     1       1     1    NO_EXTENSIONS
             RenderSetting RNst     2       1     2    NO_EXTENSIONS
          DynRelinkWrapper DRkW     2       1     2    NO_EXTENSIONS
              MPEGPosition MPGP     1       1     1    NO_EXTENSIONS
         AudioGroupSetting AGRP     1       1     1    NO_EXTENSIONS
                  omf2GMFL gmfl     0       0     0    NO_EXTENSIONS
                  omf2WINL winl     0       0     0    NO_EXTENSIONS
         ControllerSetting Cnts     2       1     2    NO_EXTENSIONS
         AvTextTranslation XFi1     1       1     1    NO_EXTENSIONS
         PortServerSetting PSvr     1       1     1    NO_EXTENSIONS
               TrackerData TKDA     1       1     2    PCLASS_EXTENSIONS6( PCLASS_EXT(TrackerOffsetTracking, 1), PCLASS_EXT(TrackerSmoothing, 2), PCLASS_EXT(TrackerJitterRemoval, 3), PCLASS_EXT(TrackerFilterDataAmt, 4), PCLASS_EXT(TrackerBoxX, 5), PCLASS_EXT(TrackerBoxY, 6) )
              TrackedParam TKPA     1       1     1    NO_EXTENSIONS
                  omf2MDTP mdtp     0       0     0    NO_EXTENSIONS
                  omf2ERAT erat     0       0     0    NO_EXTENSIONS
          TransferSettings XFER     1       1     1    NO_EXTENSIONS
          TrackerDataSlots TKDS     1       1     1    PCLASS_EXTENSIONS1( PCLASS_EXT(TrackForeground, 1))
            AMacDirLocator MACD     2       1     2    PCLASS_EXTENSIONS1( PCLASS_EXT(UTF8CanonicalPathName, 1) )
         TrackedParamSlots TKPS     1       1     1    NO_EXTENSIONS
      MachineConfigSetting DCST     2       1     2    NO_EXTENSIONS
          APaintEffectAttr PTFX     1       1     1    NO_EXTENSIONS
                  omf2CCAE ccae     0       0     0    NO_EXTENSIONS
              ACaptureMask MASK     1       1     1    NO_EXTENSIONS
             AEdgecodeClip ECCP     1       1     1    NO_EXTENSIONS
                  omf2GFXA gfxa     0       0     0    NO_EXTENSIONS
                  WinState WnSt     3       1     3    NO_EXTENSIONS
                  omf2SCLP sclp     0       0     0    NO_EXTENSIONS
             SD2Descriptor SD2D     1       1     1    NO_EXTENSIONS
              AGridSetting GRst     4       1     4    NO_EXTENSIONS
              AGrowBoxPane Grow     1       1     1    NO_EXTENSIONS
             AStrobeEffect STRB     1       1     1    NO_EXTENSIONS
            CDCIDescriptor CDCI     2       1     2    PCLASS_EXTENSIONS1( PCLASS_EXT(AlphaSampledDepth, 1) )
            PTVideoSetting PTvm     1       1     1    NO_EXTENSIONS
           AVC1394Protocol MMpa     1       1     1    NO_EXTENSIONS
                  omf2PTPP ptpp     0       0     0    NO_EXTENSIONS
          ALTCReaderDevice MMtc     1       1     1    NO_EXTENSIONS
         DigitalCutSetting DCst     6       1     6    NO_EXTENSIONS
               DIDPosition DIDP     1       1     1    NO_EXTENSIONS
                 TCMachine MMtd     1       1     1    NO_EXTENSIONS
              FakeProtocol MMpf     1       1     1    NO_EXTENSIONS
                     AClip CLIP     1       1     1    NO_EXTENSIONS
              ATCGenDevice MMtg     1       1     1    NO_EXTENSIONS
               NILProtocol MMpn     1       1     1    NO_EXTENSIONS
            MarqueeSetting MqSt     1       1     1    NO_EXTENSIONS
             MMHostSetting MMhs     1       1     1    NO_EXTENSIONS
          MMProjectSetting MMpr     1       1     1    NO_EXTENSIONS
               SBVProtocol MMps     1       1     1    NO_EXTENSIONS
               AThinSlider THIN     1       1     1    NO_EXTENSIONS
              VLANProtocol MMpv     1       1     1    NO_EXTENSIONS
            AIFCDescriptor AIFC     1       1     1    PCLASS_EXTENSIONS1( PCLASS_EXT(DataPos, 1) )
                  omf2NETL netl     0       0     0    NO_EXTENSIONS
              AMA_Settings AMAS     1       1     1    NO_EXTENSIONS
                  omf2CLSD clsd     0       0     0    NO_EXTENSIONS
      AudioMultiMixSetting AMMS     1       1     1    NO_EXTENSIONS
      AudioEffModeWinState AEWS     1       1     1    NO_EXTENSIONS
                MCFirstBin BINF     1       1     1    NO_EXTENSIONS
                  omf2DDEF ddef     0       0     0    NO_EXTENSIONS
                  omf2CPNT cpnt     0       0     0    NO_EXTENSIONS
                ATextEntry TxEn     1       1     1    NO_EXTENSIONS
      TimelineLinkageSetting TLlk     1       1     1    NO_EXTENSIONS
              CoreAttrList CATL     1       1     1    NO_EXTENSIONS
        ToolPaletteSetting TPst     1       1     1    NO_EXTENSIONS
                  omf2EDEF edef     0       0     0    NO_EXTENSIONS
          ANotSoSimpleList SMLS     1       1     1    NO_EXTENSIONS
         MediaCacheSetting ICSt     1       1     1    NO_EXTENSIONS
      DataEssenceDescriptor DATD     1       1     1    NO_EXTENSIONS
         PublishSettingsQT PBSG     1       1     1    NO_EXTENSIONS
                AParamClip PRCL     1       1     1    PCLASS_EXTENSIONS2( PCLASS_EXT(ExtrapKind, 1), PCLASS_EXT(Fields, 2) )
                 APaneBook PBOK     1       1     1    NO_EXTENSIONS
               UserProfile UPst     1       1     1    NO_EXTENSIONS
               AFloatEntry FlEn     1       1     1    NO_EXTENSIONS
            BinLayoutState Bins     1       1     1    PCLASS_EXTENSIONS1( PCLASS_EXT(binLocator, 1) )
                  omf2CMOB cmob     0       0     0    NO_EXTENSIONS
      AVideoSatelliteSetting AVSS     1       1     1    NO_EXTENSIONS
                  omf2DIDD didd     0       0     0    NO_EXTENSIONS
       AudioDuckingSetting Duck     1       1     1    NO_EXTENSIONS
             SearchSetting SRCH     1       1     1    NO_EXTENSIONS
           DecorationState Decs     1       1     1    NO_EXTENSIONS
                  omf2MOBJ mobj     0       0     0    NO_EXTENSIONS
      SourceBrowserSettings SBWS     1       1     1    NO_EXTENSIONS
                   MCState MCSt    15       1    15    NO_EXTENSIONS
               ATrackGroup TRKG     8       1     8    PCLASS_EXTENSIONS1( PCLASS_EXT(LockNumber, 1) )
    *** dump halted by exception: FATAL_ERROR
    ________ Current Program Stack _________________________________________
    ________ System Configuration __________________________________________
    System software: 10.12.6
    Machine type: MacPro6,1
    Physical RAM: 32768 Mbytes; Logical RAM: 0 Mbytes
    User name: anna
    Application info: Avid Media Composer(R) 18.5.1 Copyright 2003-2018 by Avid Technology, Inc. 48865
    ________ Processes Currently Running ___________________________________
    Address  Size     Type   Signtr ProcessName                      FileName
    00000000 00000000 'LPPA' 'wngl' "loginwindow"                    ""loginwindow""
    00000000 00000000 '????' '????' "universalaccessd"               ""universalaccessd""
    00000000 00000000 'LPPA' 'kcod' "Dock"                           ""Dock""
    00000000 00000000 'LPPA' 'iuys' "SystemUIServer"                 ""SystemUIServer""
    00000000 00000000 'LPPA' 'apcm' "ARDAgent"                       ""ARDAgent""
    00000000 00000000 'LPPA' '????' "nbagent"                        ""nbagent""
    00000000 00000000 'LPPA' '????' "cloudphotosd"                   ""cloudphotosd""
    00000000 00000000 'RDNF' 'SCAM' "Finder"                         ""Finder""
    00000000 00000000 '????' '????' "imklaunchagent"                 ""imklaunchagent""
    00000000 00000000 'LPPA' '????' "NotificationCenter"             ""NotificationCenter""
    00000000 00000000 'LPPA' '????' "com.faronics.DeepFreezeAgent"   ""com.faronics.DeepFreezeAgent""
    00000000 00000000 'LPPA' 'TPaW' "PenTabletDriver"                ""PenTabletDriver""
    00000000 00000000 'LPPA' 'akSK' "KeyAccess"                      ""KeyAccess""
    00000000 00000000 'LPPA' '????' "com.paragon-software.NTFS.fsnot" ""com.paragon-software.NTFS.fsnot""
    00000000 00000000 'LPPA' '????' "AirPlayUIAgent"                 ""AirPlayUIAgent""
    00000000 00000000 'LPPA' 'TWaW' "WacomTabletDriver"              ""WacomTabletDriver""
    00000000 00000000 'LPPA' '????' "Siri"                           ""Siri""
    00000000 00000000 'LPPA' 'TCaW' "ConsumerTouchDriver"            ""ConsumerTouchDriver""
    00000000 00000000 'LPPA' 'idaf' "FolderActionsDispatcher"        ""FolderActionsDispatcher""
    00000000 00000000 'LPPA' 'MSBA' "AvidBackgroundServicesManager"  ""AvidBackgroundServicesManager""
    00000000 00000000 'LPPA' '????' "Spotlight"                      ""Spotlight""
    00000000 00000000 'LPPA' 'TPaW' "WacomTouchDriver"               ""WacomTouchDriver""
    00000000 00000000 'LPPA' '????' "WiFiAgent"                      ""WiFiAgent""
    00000000 00000000 'LPPA' '    ' "fwGUI"                          ""fwGUI""
    00000000 00000000 'LPPA' 'MCaW' "TabletDriver"                   ""TabletDriver""
    00000000 00000000 '????' '????' "AvidApplicationManager"         ""AvidApplicationManager""
    00000000 00000000 '!CPX' '????' "ViewBridgeAuxiliary"            ""ViewBridgeAuxiliary""
    00000000 00000000 '!CPX' '????' "com.apple.dock.extra"           ""com.apple.dock.extra""
    00000000 00000000 '????' '????' "CoreServicesUIAgent"            ""CoreServicesUIAgent""
    00000000 00000000 'LPPA' 'evTA' "AvidMediaComposer"              ""AvidMediaComposer""
    00000000 00000000 'LPPA' 'pOVA' "QuickTime_OPServer"             ""QuickTime_OPServer""
    00000000 00000000 'LPPA' '????' "AvidSearch"                     ""AvidSearch""
    00000000 00000000 'LPPA' '????' "AvidBinIndexer"                 ""AvidBinIndexer""
    00000000 00000000 'LPPA' '????' "QtWebEngineProcess"             ""QtWebEngineProcess""
    00000000 00000000 'LPPA' '????' "AvidOPFrameGeneratorApp"        ""AvidOPFrameGeneratorApp""
    ________ WindowList ____________________________________________________
    Composer                 Visible     WindowKind: 7040     portRect: 0, 0, 1263, 453
    MiniHelpWindow            Hidden     WindowKind: 2040     portRect: 0, 0, 48, 12
    New Project - anna       Visible     WindowKind: 7040     portRect: 0, 0, 308, 289
    Source Browser           Visible     WindowKind: 7040     portRect: 0, 0, 640, 400
    New Project Bin          Visible     WindowKind: 7040     portRect: 0, 0, 435, 150
                              Hidden     WindowKind: 5080     portRect: 0, 0, 400, 107
    Upload/Download Queue      Hidden     WindowKind: 7040     portRect: 0, 0, 640, 480
    Background Queue          Hidden     WindowKind: 7040     portRect: 0, 0, 640, 480
    Hardware Tool             Hidden     WindowKind: 7040     portRect: 0, 0, 332, 356
    Punch-in                  Hidden     WindowKind: 7040     portRect: 0, 0, 100, 30
    DebugWindow               Hidden     WindowKind: 7040     portRect: 0, 0, 572, 276
    Timeline Clip Notes       Hidden     WindowKind: 7040     portRect: 0, 0, 670, 340
    Restrictions              Hidden     WindowKind: 7040     portRect: 0, 0, 592, 294
    Markers                   Hidden     WindowKind: 7040     portRect: 0, 0, 670, 340
    MediaCentral | UX Messages      Hidden     WindowKind: 7040     portRect: 0, 0, 492, 279
    MediaCentral | Cloud UX      Hidden     WindowKind: 7040     portRect: 0, 0, 772, 479
    Online Resources          Hidden     WindowKind: 7040     portRect: 0, 0, 1050, 700
    Avid Marketplace          Hidden     WindowKind: 7040     portRect: 0, 0, 1050, 700
    Find                      Hidden     WindowKind: 7040     portRect: 0, 0, 901, 506
                              Hidden     WindowKind: 7040     portRect: 0, 0, 280, 256
    Motion Effect Editor      Hidden     WindowKind: 5040     portRect: 0, 0, 228, 356
    Transfer Status           Hidden     WindowKind: 7040     portRect: 0, 0, 492, 279
    Color Info                Hidden     WindowKind: 7040     portRect: 0, 0, 100, 30
    Dynamic Media Folders      Hidden     WindowKind: 7040     portRect: 0, 0, 700, 340
    Digital Cut Tool          Hidden     WindowKind: 7040     portRect: 0, 0, 461, 410
    Avid Calculator           Hidden     WindowKind: 5040     portRect: 0, 0, 242, 226
    Capture Tool              Hidden     WindowKind: 7040     portRect: 0, 0, 400, 646
    DX Output Tool            Hidden     WindowKind: 7040     portRect: 0, 0, 206, 446
    Video Input Tool (Active)      Hidden     WindowKind: 6040     portRect: 0, 0, 187, 229
    Tool Palette              Hidden     WindowKind: 6040     portRect: 0, 0, 232, 38
    PopupWindow               Hidden     WindowKind: 6040     portRect: 0, 0, 120, 22
    Passthrough Mix Tool - Untitled      Hidden     WindowKind: 7040     portRect: 0, 0, 324, 300
    Audio Tool                Hidden     WindowKind: 6040     portRect: 0, 0, 160, 245
    Audio Suite Effect Dialog      Hidden     WindowKind: 7040     portRect: 0, 0, 100, 30
    AudioSuite Window         Hidden     WindowKind: 7040     portRect: 0, 0, 340, 134
    Audio EQ Tool             Hidden     WindowKind: 7040     portRect: 0, 0, 172, 319
    Audio Track Effect Tool      Hidden     WindowKind: 7040     portRect: 0, 0, 100, 30
    Audio Mixer               Hidden     WindowKind: 7040     portRect: 0, 0, 273, 598
    Timecode                  Hidden     WindowKind: 6040     portRect: 0, 0, 340, 60
    PopupWindow               Hidden     WindowKind: 6040     portRect: 0, 0, 22, 120
    Timeline                 Visible     WindowKind: 7040     portRect: 0, 0, 1262, 628
    Color Correction          Hidden     WindowKind: 7040     portRect: 0, 0, 1024, 219
    Tracking Window           Hidden     WindowKind: 7040     portRect: 0, 0, 462, 252
    Effect Editor             Hidden     WindowKind: 5040     portRect: 0, 0, 270, 60
    Effect Palette            Hidden     WindowKind: 5040     portRect: 0, 0, 235, 155
    Communication (Serial) Ports Tool      Hidden     WindowKind: 7040     portRect: 0, 0, 292, 65
    Production Management Window      Hidden     WindowKind: 7040     portRect: 0, 0, 400, 200
    Console                   Hidden     WindowKind: 7040     portRect: 0, 0, 632, 136
    ________ Binary Modules Loaded _________________________________________
    ________ Device Drivers Loaded _________________________________________
    ________ Undo Manager __________________________________________________
    > AUndoMgrMem (object: 0x6080002ACD28, size: 166264)
      MaxLevels: 100
      CurrentGeneration: 1
      LastLifeID: 41
      UndoRedoMode: FALSE
      objList items: 41 (144160 bytes)
      DeadList items: 0 (21712 bytes)
      Future contains 0 layers (Total Size: 152 bytes)
      Past contains 0 layers (Total Size: 152 bytes).
    ________ Settings, Current Active ______________________________________
    Audio "Untitled":
        > AudioSetting (object: 0x628000EF7388, size: 120)
          this: 108301911028616
       (LID 0)AudioSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 16
    Audio Ducking "Untitled":
        > AudioDuckingSetting (object: 0x60000015F328, size: 160)
          this: 105553117705000
       (LID 0)AudioDuckingSetting
          IsDirty:
          IsActive:
          CanBeActive:
          Type: 16
    Audio Multi-Mix "Untitled":
        > AudioMultiMixSetting (object: 0x610002095CC8, size: 72)
          this: 106652662062280
       (LID 0)AudioMultiMixSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    Audio Project "Untitled":
        > AudioProjectSetting (object: 0x6100010C0468, size: 96)
          this: 106652645459048
       (LID 0)AudioProjectSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    Audio Track Grouping "Untitled":
        > AudioGroupSetting (object: 0x60000030D1D8, size: 128)
          this: 105553119465944
       (LID 0)AudioGroupSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    Bin "Untitled":
        > ABinSetting (object: 0x7FAB36E722A8, size: 600)
          this: 140373337252520
       (LID 0)ABinSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    Digitize "Untitled":
        Digitize "Untitled" [0x7fab2b1a3808] USER 1 refs, dirty, active
         digbinname "",
         panesVisible {1,1,1,1,1,1,1,0},
         tcOn 1, deckOn 1, logModeOn 0, deckNum 1, iPassThru 0,
         iAskBeforeDiscard 1, iLogErrors 0, iHonorTrack 1, iHonorAudioRate 0, iHonorVideoRez 0, iHonorAudioSampleSize 0,
         iHonorVideoRate 0, iDiscontinuousDigitize 0, iAllowDiscoOut 0,
         iDigitalFormat 0, iPullFlagLine 12, iUseWF 0, iSwitchToEmptiest 0, iPauseDeckWhenDone 0,
         iPrerollMethod 1,
         iSwitchWithTimeLeft 0, iMinutesLeft 1, iArmRemotely 0, iSingleFrameCapture 0, iLoadDigitized 0, iDigitizeAMode 1,
         iDeleteShortClips 0, iShortClipSecondsLimit 1, iDeleteSubClips 1, iAutoClean 1, iCleanAlways 1, iAutoSequence 1, iInsertFiller 1
         iDigitizePulldownState (NTSC film only) 1,
        iSelTCconfigs[0] { tcType 2, track 65537, selGenSpec 1, tcStyle 1 },
        iSelTCconfigs[1] { tcType 1, track 65537, selGenSpec 1, tcStyle 1 },
        iSelTCconfigs[2] { tcType 2, track 65538, selGenSpec 1, tcStyle 1 },
        iSelTCconfigs[3] { tcType 1, track 65538, selGenSpec 1, tcStyle 1 },
         FKey(1) = Start Subclip,
         FKey(2) = End Subclip,
         FKey(3) = Add Red Marker,
         FKey(4) = End Locator Entry,
         FKey(5) = Add Red Marker,
         FKey(6) = Add Green Marker,
         FKey(7) = Add Blue Marker,
         FKey(8) = Add Cyan Marker,
         FKey(9) = Add Magenta Marker,
         FKey(10) = Add Yellow Marker,
         FKey(11) = Add Black Marker,
         FKey(12) = Add White Marker,
    Color Management "Untitled":
        > ColorManagementSettings (object: 0x60000029AB38, size: 64)
          this: 105553118997304
       (LID 0)ColorManagementSettings
          IsDirty:
          IsActive:
          CanBeActive:
          Type: 18
    Communication (Serial) Ports "Untitled":
        Communication (Serial) Ports "Untitled" [0x7fab33b6e408] SITE 1 refs, dirty, active
        iDeckPort: hasDevice = 0
            inDev:
            outDev:
        iEvertzPort: hasDevice = 0
            inDev:
            outDev:
        iVTREmulationPort: hasDevice = 0
            inDev:
            outDev:
        iDroidPort: hasDevice = 0
            inDev:
            outDev:
        iEDLPort: hasDevice = 0
            inDev:
            outDev:
        iSteenbeckPort: hasDevice = 0
            inDev:
            outDev:
        iSlidersPort: hasDevice = 1
            inDev:
            outDev:
    Composer "Untitled":
        Composer "Untitled" [0x7fab374ac7a8] USER 1 refs, active
        iShowButs 1, iShowButs2 1, iSyncPoint 0, iShowShads 0, iSrcRecTCs 1,
        iCenterTCs 1, iTickMarks 1, iShowMenu 1, iShowBlip 0, iBrighter 0,
        iCwJumps 1, iTlJumps 1, iCwMini 1, iColorFraming 0, iFilmStyleDissolves 0,
        iShowAvid 1, iShowTrackPanel 0, iShowSubClip 1, iShowName 1, iSrcRecTCs2 1,
        iAspect16x9SD 0, iAspect16x9HD 1, iShowPosBar 1,
        iMonWidth 630, iMonHeight 354, iDurTxtFormat 1, iColorComp 28672,
        iSelTCconfigs[0] { tcType 1, track 65538, selGenSpec 1, tcStyle 1 },
        iSelTCconfigs[2] { tcType 2, track 65538, selGenSpec 0, tcStyle 1 },
        iSelTCconfigs[3] { tcType 2, track 65537, selGenSpec 0, tcStyle 1 },
        iHeads_FF_REW 1, iTails_FF_REW 0, iLocators_FF_REW 0, iIgnoreTrackLights_FF_REW 0,
        iRenderOnTheFly 1, iRenderToSrcDisk 1, iAutoTrackCreation 1, iAutoTrackEnable 1, iNoMultiPlay 0,
        iSrcCmds:
            00-07: 185F.-- 1860.-- 1840.-- 183F.-- 1841.-- 1839.-- 1842.-- 1843.--
            08-0F: 1846.-- 186A.-- 0000.-- 189C.-- 184C.-- 185D.-- 185C.-- 183B.--
            10-17: 183A.-- 183C.-- 184B.-- 0000.-- 0000.-- 0000.--
        iRecCmds:
            08-0F: 184D.-- 184A.-- 1849.-- 189C.-- 184C.-- 185D.-- 185C.-- 183B.--
            10-17: 183A.-- 183C.-- 1897.-- 1899.-- 1867.-- 1850.--
        iCWCmds:
            00-07: 1847.-- 1862.-- 1848.--
        iRecFXCmds:
            00-07: 185F.-- 1860.-- 17F3.-- 1840.-- 183F.-- 1839.-- 17FA.-- 1881.--
            08-0F: 17F5.-- 17F0.-- 17F1.-- 0000.-- 184E.-- 185D.-- 185C.-- 1841.--
            10-17: 183A.-- 1842.-- 1897.-- 1899.-- 187A.-- 189E.--
    Controller Settings "Untitled":
        > ControllerSetting (object: 0x7FAB36DC5FE8, size: 736)
          this: 140373336547304
       (LID 0)ControllerSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 16
    Correction "Untitled":
        > ACorrectionModeSetting (object: 0x7FAB36DC6668, size: 416)
          this: 140373336548968
       (LID 0)ACorrectionModeSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    Deck Configuration "Untitled":
        > MachineConfigSetting (object: 0x608000CAC668, size: 80)
          this: 106102885369448
       (LID 0)MachineConfigSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 8
    Deck Preferences "Untitled":
        > DeckSetting (object: 0x618001AFCB08, size: 112)
          this: 107202412006152
       (LID 0)DeckSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 16
    Desktop Play Delay "Untitled":
        > DIOSyncOffsetSetting (object: 0x6080022804B8, size: 72)
          this: 106102908257464
       (LID 0)DIOSyncOffsetSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 8
    Digital Cut "Untitled":
        > DigitalCutSetting (object: 0x618001AFCC08, size: 112)
          this: 107202412006408
       (LID 0)DigitalCutSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    Dynamic Relink "Untitled":
        > DynRelinkWrapper (object: 0x600001CD78B8, size: 104)
          this: 105553146509496
       (LID 0)DynRelinkWrapper
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    Effect Command Page "Untitled":
        > FxCmdPalSetting (object: 0x600000324428, size: 144)
          this: 105553119560744
       (LID 0)FxCmdPalSetting
          IsDirty:
          IsActive:
          CanBeActive:
          Type: 18
    Effect Editor "Untitled":
        > EffectSetting (object: 0x6180018B9808, size: 80)
          this: 107202409633800
       (LID 0)EffectSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    Email "Untitled":
        > Email_Settings (object: 0x6180005CC6C8, size: 224)
          this: 107202389788360
       (LID 0)Email_Settings
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    Export "Send To QT Movie":
        > ExportSetting (object: 0x7FAB36DCCC38, size: 752)
          this: 140373336575032
       (LID 0)ExportSetting
          Name: Send To QT Movie
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    Film and 24P "Untitled":
        > FilmSetting (object: 0x6000002EB408, size: 120)
          this: 105553119327240
       (LID 0)FilmSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    Full Screen Playback "Untitled":
        Full Screen Playback "Untitled" [0x6000013717c8] USER 1 refs, dirty, active
        Scaling 3
        DiplayBothField 0
        MonitorLeft 0
        MonitorRight 1920
        MonitorTop 0
        MonitorBottom 1200
    General "Untitled":
        > AGeneralSetting (object: 0x7FAB33556208, size: 2176)
          this: 140373277368840
       (LID 0)AGeneralSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    Grid "Untitled":
        > AGridSetting (object: 0x6180003A1B28, size: 216)
          this: 107202387516200
       (LID 0)AGridSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    HDV Digital Cut "Untitled":
        HDV Digital Cut "Untitled" [0x6180056942d8] USER 1 refs, active
        mStreamSource 0
        mDeleteStream 0
    Import "Untitled":
        > ImportSetting (object: 0x7FAB36DCE798, size: 672)
          this: 140373336582040
       (LID 0)ImportSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    Interface "Untitled":
        > UISetting (object: 0x6180008A3608, size: 88)
          this: 107202392765960
       (LID 0)UISetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    Keyboard "MC English (United States)":
        Keyboard "MC English (United States)" [0x7fab198e0008] USER 1 refs, active
        state 0:
        00-07: 183D.-- 183E.-- 1844.-- 1845.-- 187C.-- 1846.-- 184A.-- 1849.--
        08-0F: 1850.-- 1847.-- 1839.-- 1848.-- 183B.-- 183C.-- 1841.-- 1842.--
        10-17: 1874.-- 1843.-- 185D.-- 185C.-- 1840.-- 183F.-- 183A.-- 1839.--
        18-1F: 185B.-- 1858.-- 1856.-- 185A.-- 1857.-- 1859.-- 1870.-- 1842.--
        20-27: 1876.-- 186F.-- 1841.-- 186E.-- 0000.-- 187E.-- 1853.-- 17F3.--
        28-2F: 1854.-- 1883.-- 1897.-- 1864.-- 1866.-- 187F.-- 1863.-- 1865.--
        30-37: 1839.-- 1839.-- 1839.-- 0000.-- 0000.-- 1851.-- 0000.-- 0000.--
        38-3F: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.--
        40-47: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.--
        48-4F: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.--
        50-57: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.--
        58-5F: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.--
        60-67: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 18E3.-- 0000.-- 18E5.--
        68-6F: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 18E4.-- 0000.-- 18E6.--
        70-77: 0000.-- 0000.-- 0000.-- 17D6.-- 0000.-- 0000.-- 0000.-- 17D7.--
        78-7F: 0000.-- 0000.-- 0000.-- 1840.-- 183F.-- 1B62.-- 1B57.-- 0000.--
        state 1:
        00-07: 1877.-- 1875.-- 1872.-- 1873.-- 0000.-- 1871.-- 0000.-- 0000.--
        08-0F: 0000.-- 0000.-- 0000.-- 0000.-- 18A7.-- 18A9.-- 18A6.-- 18A8.--
        10-17: 0000.-- 18AB.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.--
        18-1F: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.--
        20-27: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 1924.-- 0000.-- 0000.--
        28-2F: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.--
        30-37: 1923.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.--
        60-67: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 18E7.-- 0000.-- 18E9.--
        68-6F: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 18E8.-- 0000.-- 18EA.--
        70-77: 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.-- 0000.--
        78-7F: 0000.-- 0000.-- 0000.-- 1840.-- 183F.-- 17D5.-- 17D4.-- 0000.--
    Link "Untitled":
        > AMA_Settings (object: 0x7FAB198E4208, size: 1464)
          this: 140372844888584
       (LID 0)AMA_Settings
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    ListToolSettings "Default EDL":
        > ListToolSettings (object: 0x618005693F18, size: 64)
          this: 107202474491672
       (LID 0)ListToolSettings
          IsDirty:       IsActive:
          CanBeActive:
          Type: 20
    Locator "Untitled":
        Locator "Untitled" [0x6000018ba708] PROJ 1 refs, active
        mShowImages 0
        mShowMetaSync 0
        mShowType 1
        mDisablePopup 0
        mImageColWidth 100
    Media Cache "Untitled":
        > MediaCacheSetting (object: 0x608002281A98, size: 72)
          this: 106102908263064
       (LID 0)MediaCacheSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 8
    Media Creation "Untitled":
        > MediaCreationSetting (object: 0x7FAB37E7CFE8, size: 920)
          this: 140373354074088
       (LID 0)MediaCreationSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    MediaCentral Server "Untitled":
        > MMHostSetting (object: 0x7FAB3737CDF8, size: 648)
          this: 140373342539256
       (LID 0)MMHostSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 8
    MediaCentral User "Untitled":
        > MMUserSetting (object: 0x6180059EA008, size: 240)
          this: 107202477989896
       (LID 0)MMUserSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 16
    Mouse "Untitled":
        Mouse "Untitled" [0x618001afea88] USER 1 refs, active
        mHorizontalSpeed 3
        mVerticalSpeed 3
        mMouseButton3CmdNum 0
        mMouseButton4CmdNum 0
        mMouseButton5CmdNum 0
        mMouseButton3ShiftCmdNum 0
        mMouseButton4ShiftCmdNum 0
        mMouseButton5ShiftCmdNum 0
        mMouseButton3CtrlCmdNum 0
        mMouseButton4CtrlCmdNum 0
        mMouseButton5CtrlCmdNum 0
        mMouseButton3AltCmdNum 0
        mMouseButton4AltCmdNum 0
        mMouseButton5AltCmdNum 0
    Passthrough Mix Tool "Untitled":
        > AudioPassthruMixerSetting (object: 0x6280012D6738, size: 96)
          this: 108301915088696
       (LID 0)AudioPassthruMixerSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    PortServer "Untitled":
        > PortServerSetting (object: 0x628000E942D8, size: 72)
          this: 108301910622936
       (LID 0)PortServerSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 8
    Pro Tools Video "Untitled":
        > PTVideoSetting (object: 0x618005693DD8, size: 72)
          this: 107202474491352
       (LID 0)PTVideoSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    Production Management Folder "Untitled":
        > MMProjectSetting (object: 0x7FAB34633208, size: 1104)
          this: 140373295051272
       (LID 0)MMProjectSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    PublishSettings_DefaultVariants "PublishSettings_DefaultVariants":
        > PublishSettingsQT (object: 0x618005693D38, size: 72)
          this: 107202474491192
       (LID 0)PublishSettingsQT
          IsDirty:       IsActive:
          CanBeActive:
          Type: 17
    Remote Play and Capture "Untitled":
        > VTREmulSetting (object: 0x6280006AA748, size: 88)
          this: 108301902325576
       (LID 0)VTREmulSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 8
    Render "Untitled":
        > RenderSetting (object: 0x6180018B6088, size: 88)
          this: 107202409619592
       (LID 0)RenderSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    Restriction "Untitled":
        Restriction "Untitled" [0x6280004be368] PROJ 1 refs, active
        mShowImages 1
        mShowType 1
        mDisablePopup 0
        mImageColWidth 100
    S3D "Untitled":
        S3D "Untitled" [0x628001088c58] PROJ 1 refs, active
    4392190096isparity Near -1.000000
    4392190096isparity Far 2.000000
    Safe Colors "Untitled":
        > SafeColorSetting (object: 0x628000937DE8, size: 152)
          this: 108301905001960
       (LID 0)SafeColorSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    Script "Untitled":
        > ScriptSetting (object: 0x618000AD77D8, size: 96)
          this: 107202395076568
       (LID 0)ScriptSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 16
    Search "Untitled":
        > SearchSetting (object: 0x628001089108, size: 72)
          this: 108301912674568
       (LID 0)SearchSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    Search User "Untitled":
        > SearchUserSetting (object: 0x6080006834D8, size: 64)
          this: 106102878909656
       (LID 0)SearchUserSetting
          IsDirty:
          IsActive:
          CanBeActive:
          Type: 16
    Sharing "Untitled":
        > SharedSetting (object: 0x7FAB2AC14608, size: 2120)
          this: 140373133444616
       (LID 0)SharedSetting
          IsDirty:
          IsActive:
          CanBeActive:
          Type: 16
    Source Browser "Untitled":
        > SourceBrowserSettings (object: 0x6180018B9C28, size: 88)
          this: 107202409634856
       (LID 0)SourceBrowserSettings
          IsDirty:
          IsActive:
          CanBeActive:
          Type: 17
    Target "Untitled":
        > TargetSetting (object: 0x6280012D6F88, size: 96)
          this: 108301915090824
       (LID 0)TargetSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    Timecode Window "Untitled":
        Timecode Window "Untitled" [0x7fab198f3808] USER 1 refs, active
        iTCFont 4, iTCFace 0, iNumVisible 1,
        iSelTCconfigs[0] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[1] { tcType 3, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[2] { tcType 4, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[3] { tcType 5, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[4] { tcType 6, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[5] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[6] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[7] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[8] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[9] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[10] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[11] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[12] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[13] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[14] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[15] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[16] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[17] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[18] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[19] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[20] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[21] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[22] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[23] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[24] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[25] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[26] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[27] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[28] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[29] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[30] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[31] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[32] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[33] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[34] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[35] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[36] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[37] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[38] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[39] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[40] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[41] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[42] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[43] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[44] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[45] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[46] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
        iSelTCconfigs[47] { tcType 2, track 65537, selGenSpec 1, tcStyle 1, tcLnum 0 },
    Timeline "Untitled":
        > ATLSetting (object: 0x6000000BCC88, size: 88)
          this: 105553117039752
       (LID 0)ATLSetting
          IsDirty:
          IsActive:
          CanBeActive:
          Type: 18
    Timeline Notes "Untitled":
        > TLNotesToolSettings (object: 0x608000497C58, size: 72)
          this: 106102876896344
       (LID 0)Timeline Notes
          IsDirty:
          IsActive:
          CanBeActive:
          Type: 16
    Timeline View Linkage "Untitled":
        > TimelineLinkageSetting (object: 0x6000004E9088, size: 112)
          this: 105553121415304
       (LID 0)TimelineLinkageSetting
          IsDirty:
          IsActive:
          CanBeActive:
          Type: 16
    Title tool "Untitled":
        > MarqueeSetting (object: 0x6180056936F8, size: 72)
          this: 107202474489592
       (LID 0)MarqueeSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 16
    Tool Palette "Untitled":
        > ToolPaletteSetting (object: 0x6000000BCE08, size: 88)
          this: 105553117040136
       (LID 0)ToolPaletteSetting
          IsDirty:
          IsActive:
          CanBeActive:
          Type: 16
    AvidNet "Untitled":
        AvidNet "Untitled" [0x618001afeb88] USER 1 refs, active
          OffAvidNet: ,Notify Enabled Prompt
          PromptTM: ,Prompt Wait,Timeout 10, Update 5
    OutputMix = Stereo
    Transcode before Send to Playback Flag = False
    Transcode before Send to Playback Resolution Threshhold Enable = True
    Transcode before Send to Playback Resolution Threshhold = 1237
    Trim "Untitled":
        Trim "Untitled" [0x618001afeb08] USER 1 refs, active
        iTrimModeMini 0, iTrimModeMiniTrans 0, iTrimModeAutoFocus 0
        iTrimModeAllowPosChange 0, iTrimLeftLoopEU 60, iTrimRightLoopEU 60, iTrimInterLoopEU 140733193388032,
        iTrimPauseTimeout 128849018895, iTrimMarkTimeout 30, iTrimAnimTimeout 60,
        iRenderOnTheFly 0, iDualRolling 1, iJKLSupport 1
        iTMCmds:
            00-07: 187A.-- 1862.-- 188C.-- 1897.-- 1863.-- 1864.-- 1865.-- 1866.--
            08-0F: 0000.-- 0000.-- 187F.-- 1883.-- 0000.-- 0000.-- 0000.-- 0000.--
    User Profile "Untitled":
        > UserProfile (object: 0x6180018B6208, size: 80)
          this: 107202409619976
       (LID 0)UserProfile
          IsDirty:       IsActive:
          CanBeActive:
          Type: 18
    Video Display "Untitled":
        > MonitorSetting (object: 0x628000116AD8, size: 136)
          this: 108301896477400
       (LID 0)MonitorSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    Video Input "Untitled":
        > VideoInputSetting (object: 0x600001C9B178, size: 64)
          this: 105553146261880
       (LID 0)VideoInputSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 32
    Video Output "Untitled":
        > VideoOutputSetting (object: 0x7FAB370A3A98, size: 424)
          this: 140373339552408
       (LID 0)VideoOutputSetting
          IsDirty:
          IsActive:
          CanBeActive:
          Type: 32
    Video Satellite "Untitled":
        > AVideoSatelliteSetting (object: 0x6280001B8B88, size: 208)
          this: 108301897141128
       (LID 0)AVideoSatelliteSetting
          IsDirty:       IsActive:
          CanBeActive:
          Type: 8
    Workspace "Untitled":
    Workspace View "Edit1920x1123x1":
    ________ Mob Manager ___________________________________________________
    > AObject (object: 0x6100000EC488, size: 233240)
      Lookups total:       1452
      Lookups with hint:    432
         hint hits:         180
         cache hits:          0
         htable hits:          922
         failures:          350
          Main Mobs Hash Table
        HashTable Size:          5557    (5313 empty, max chain len 2)
        ElementArray Size:      3000     (ItemSize 8, HTElement Size 24)
        Number of Items:       246
        Load Factor (numitems/tablesize):      0.04
        Average Chain Len (numitems/num buckets used in table):      1.01
          Quarantined Mobs Hash Table
        HashTable Size:          5557    (5557 empty, max chain len 0)
        Number of Items:         0
        Load Factor (numitems/tablesize):      0.00
      No batch active.
      Main mobs:        246 (Total Size: 418495 bytes)
      Quarantined mobs:   0 (Total Size: 0 bytes)
      Total batches committed:      4
      Total mobs committed:       240
      Total conflicts resolved:     0
      Average mobs/commit:      60.00
      Average conflicts/commit:  0.00
      Total batches aborted:        0
      Total mobs aborted:           0
    ________ Mobs By Type __________________________________________________
    [Note: there are roughly 80 unreferenced master mobs present on all systems (well-known mobs).]
    Category                  Count            Memory Total      Memory Average    Unreferenced Count
            numSequences            0 mobs,          0 bytes,          0 bytes,          0 mobs)
              numMasters           82 mobs,     126364 bytes,       1541 bytes,         81 mobs)
             numSubClips            0 mobs,          0 bytes,          0 bytes,          0 mobs)
               numGroups            0 mobs,          0 bytes,          0 bytes,          0 mobs)
       numGroupIndirects            0 mobs,          0 bytes,          0 bytes,          0 mobs)
              numEffects            0 mobs,          0 bytes,          0 bytes,          0 mobs)
              numMotions            0 mobs,          0 bytes,          0 bytes,          0 mobs)
        numOtherLogicals            1 mobs,      12389 bytes,      12389 bytes,          0 mobs)
                numFiles           83 mobs,     153255 bytes,       1846 bytes,          0 mobs)
               numSFiles           80 mobs,     126487 bytes,       1581 bytes,          0 mobs)
                numTapes            0 mobs,          0 bytes,          0 bytes,          0 mobs)
                numFilms            0 mobs,          0 bytes,          0 bytes,          0 mobs)
               numNagras            0 mobs,          0 bytes,          0 bytes,          0 mobs)
       numPrecompMasters            0 mobs,          0 bytes,          0 bytes,          0 mobs)
         numPrecompFiles            0 mobs,          0 bytes,          0 bytes,          0 mobs)
        numPrecompSFiles            0 mobs,          0 bytes,          0 bytes,          0 mobs)
                numStubs            0 mobs,          0 bytes,          0 bytes,          0 mobs)
                numNulls            0 mobs,          0 bytes,          0 bytes,          0 mobs)
                 numFwds            0 mobs,          0 bytes,          0 bytes,          0 mobs)
       numUnknownMasters            0 mobs,          0 bytes,          0 bytes,          0 mobs)
     numUnknownPhysicals            0 mobs,          0 bytes,          0 bytes,          0 mobs)
          numUnknownMobs            0 mobs,          0 bytes,          0 bytes,          0 mobs)
    Total number of mobs in memory: 246
    Total amount of memory consumed by mobs:     418495 bytes (Average       1701 bytes per mob)
