Latest post Sat, Aug 25 2018 11:53 PM by Martin Fox. 3 replies.
  • Mon, Aug 20 2018 9:45 PM
    • cls105
    • los angeles
    • Posts 403
    • Points 5,195
    Being able to map "mixer pulldown menus"
    I find myself always bringing up the mixer for added clips and bringing up pull down menu to give it the same gain as the surrounding clips.
    It would be cool if I could map "Set level on track - in/out" on keyboard without having to bring up the mixer and using mouse for pulldown menu.
    MC 2018.12.1, diy x299 7940x 4.5ghz OC, 1080ti, 128gb ram, w10 pro (1803) DM me on instagram for tech Q's: dvhaime [view my complete system specs]
  • Mon, Aug 20 2018 10:42 PM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 218
    • Points 2,290
    Re: Being able to map "mixer pulldown menus"
    Agreed, I’m using a macro to do this job, makes it much easier. Also using a macro to target which track needs adjusting, and then use the shift & arrow keys to raise or lower volume.
  • Sat, Aug 25 2018 8:35 PM In reply to
    • cls105
    • los angeles
    • Posts 403
    • Points 5,195
    Can you explain this macro in more detail?  Thank you
  • Sat, Aug 25 2018 11:53 PM In reply to
    • Martin Fox
    • Sydney Australia
    • Posts 218
    • Points 2,290
    I manually set the in out marks and set the tracks I want to adjust,
    i then trigger the macro with the key combo - command F12 - then
    the macro selects the mixer,then targets the drop down menu, steps down to set volume in to  out.
    ill post a screen shot of the macro when I’m back at work.
