Latest post Tue, Aug 21 2018 10:36 AM by Kestiu. 7 replies.
  • Fri, Aug 17 2018 11:58 AM
    • Kestiu
    • Joined on Tue, Apr 17 2018
    • Posts 6
    • Points 70
    Scale From Legal to Full Range
    Hey there,
    Even though I did a fair bit of research and asked several people for expertise there doesnt seem to be a clear answer to this anywhere.
    Basically, we have used MXF files for our exports that come out of Nucoda in the default Legal Range color space. However we exported everything using Scale From Legal to Full Range setting. H264, Quicktime codec. The exports will be watched on various monitors, projectors and TV screens (not online). As I can see looking at the exports now - the blacks do seem crushed when watching it on Quicktime player but they seem fine when watching it with VLC.
    My question is: did we make a mistake by exporting everything with the Full Range setting? Even though the MXF's we used as I mentioned were exported in Legal range (16 - 235) so technically this export setting should scale it to full range (00 - 250).
  • Sat, Aug 18 2018 8:37 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,308
    • Points 40,035
    Re: Scale From Legal to Full Range
    Kestiu:
    You should not Scale from Legal to Full Range for the devices noted.  Legal is Avid's label for broadcast type devices. Full range is for use on computer based monitors / viewing, not what you described.
    Jef
    Jef Huey
  • Sun, Aug 19 2018 8:01 AM In reply to
    Friends don’t let friends do custom QT h264 exports from inside Media Composer. It uses the old, slow QT engine and Apple QT h264 codec that is notorious for causing gamma shifts and mis-flagging content. So what appears to happen is that you expand to 0-255, while the encoder still flags the content as 16-235. QT player then reads that flag and ‘corrects’ for that, while VLC does not.
    I usually export same-as-source from MC, then encode to h264 in Handbrake. Fast and good quality (you need to tinker with the settings, though).
  • Sun, Aug 19 2018 2:05 PM In reply to
    • jef
    • Maryland
    • Posts 3,308
    • Points 40,035
    Job ter Burg:
    T-shirt anyone?
    Smile
    Jef
    Jef Huey
  • Mon, Aug 20 2018 5:32 PM In reply to
    • Posts 10,018
    • Points 215,715
    jef:
    Job ter Burg:
    T-shirt anyone?
    Smile
    Jef
    OMG I belted out a laugh!
    M
  • Mon, Aug 20 2018 11:48 PM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 218
    • Points 2,290
    Very difficult to control the playback environment.
    if you are watching on a tv or a projector then the display device will scale “legal” levels to full range (perceptually) for you. If you are watching on a computer monitor it won’t scale, but the player might!
    I do mp4 files full range, expecting they will be played on a computer. I do professional codecs “legal” expecting they will be played on a video monitor.
    Vimeo for example expects legal range, and it will scale levels in its player.
    OUCH!
  • Tue, Aug 21 2018 2:08 AM In reply to
    • jef
    • Maryland
    • Posts 3,308
    • Points 40,035
    Martin Fox:
    Ain't that the truth.  Even between two of the same monitors in the same room sometimes .....
    Jef
    Jef Huey
  • Tue, Aug 21 2018 10:36 AM In reply to
    • Kestiu
    • Posts 6
    • Points 70
    I see, thank you.
    Thank you all for replying, I have a better understanding of this issue now. We re-exported everything using Legal range as most likely the devices used for screening will read the file as legal range and scale it automatically.
