Latest post Fri, Aug 17 2018 12:27 AM by dyllio. 27 replies.
Page 2 of 2 (28 items) < Previous 1 2
  • Wed, Aug 15 2018 7:55 PM In reply to
    • Fish
    • Joined on Sat, Oct 15 2005
    • Filet Post, Halifax NS
    • Posts 534
    • Points 6,475
    Re: MC takes a break for no particular reason
    Also...here are my plugins. All standard issue exempty nablet which we need to encode our Sony F5 video clips.
    2012 Westmere MacPro 2 x 2.66 GHz 6-Core Intel Xeon) 6 GB 1333 MHz DDR3 ECC ATI Radeon HD 5870 1024 MB As of Jan 2015 - OS X 10.9.5 (13F34) [view my complete system specs]
    AVID man, AVID fan (since 1993 with version 4.5 - before multiple tracks!)...like to solve my own problems and I try not to bother anyone unless I'm really stumped.
  • Wed, Aug 15 2018 8:12 PM In reply to
    Well, the delay comes when you see AMPIPluginDSM loading...and eventually MC times out and hangs for a bit. That process is responsible for licensing and validating audio plugins, including AudioSuite.
    Is this a co-install with ProTools? If so, you might want to try uninstalling both, then install PT, then install MC.
  • Wed, Aug 15 2018 9:03 PM In reply to
    • Fish
    • Posts 534
    • Points 6,475
    It's not a co-install with PT. No PT on my system. My system is actually pretty clean as I recently did a total wipe and reinstall from the ground up.
    Why does it always need to check licenses? Seems like one time should do the trick.The startup process on the MC is already too long, imho.
  • Wed, Aug 15 2018 9:21 PM In reply to
    • Posts 9,712
    • Points 211,650
    I have basic MC on mine system and the pplug in you have that i dont are:
    BF-76
    Channelstrip
    Elevenlite
    LoFi
    Mastermeter
    Maxim
    PitchII
    RectiFi
    SanSamp
    VariFi
    Can you move those to a new folder on the desktop and try again?
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Wed, Aug 15 2018 9:50 PM In reply to
    • Fish
    • Posts 534
    • Points 6,475
    Tried it...no positive effect.
    But if I take the ENTIRE audio folder out...it sails right through.
    I'm goign to take a guess that my plugins got "polluted" somehow and do a fresh install of the MC software with it's native plugs (only).
    See if that does the trick.
  • Wed, Aug 15 2018 10:02 PM In reply to
    • Posts 9,712
    • Points 211,650
    Report back Fish.... this one is a head scrtacher
  • Thu, Aug 16 2018 12:25 AM In reply to
    • Fish
    • Posts 534
    • Points 6,475
    I literally tossed the entire Avid folder from application support in the trash, ran every uninstaller, restarted, installed a clean 2018.8 version and it still hangs on that screen.  (sigh)
    I checked and the standard install added a slew of audio plugins in there including ones you said you didn't have. And I think some new ones.
    So, I dunno what the heck I'm doing wrong here.
  • Thu, Aug 16 2018 4:08 PM In reply to
    My plugins match yours, Fish...and I don't have any extra ones either.
    So, as long as you move the audio plugins folder to a new location, you boot much faster? But when back in it's spot the delay returns?
  • Thu, Aug 16 2018 4:32 PM In reply to
    • Fish
    • Posts 534
    • Points 6,475
    Correct.
  • Thu, Aug 16 2018 4:59 PM In reply to
    • Posts 9,712
    • Points 211,650
    Possible that one of those needs an update or is corrupted ?
  • Thu, Aug 16 2018 6:05 PM In reply to
    • Fish
    • Posts 534
    • Points 6,475
    Next step is to try isolating a possible culprit..
    Stand by.
  • Thu, Aug 16 2018 8:06 PM In reply to
    • Fish
    • Posts 534
    • Points 6,475
    Well, I tried the 1/2 and 1/2 approach that one uses to find a corrupt video file.
    Turns out, eitehr way it still gave me the pause at start up. (???)
    So I then I tried just one plug-in in the folder and it worked.
    Then i tried picking a bunch and it was slow again.
    So then I just put in those plug-ins that I use teh most frequently and it gives me a slight pause, but one that is much more manageable.
    So...that doesn't "fix" the startup problem.
    And it doesn't give me relief from my original post (the MC taking a pause for a few mins for no reason).
    Here is the list of what is currently in my folder and what is removed.
  • Fri, Aug 17 2018 12:27 AM In reply to
    • dyllio
    • Los Angeles
    • Posts 57
    • Points 590
    I've seen similar things on 8.9.4 Shared project - Mac Pro trashcan OS 10.12.6.   Only myself and another editor are experiencing the hangs.  Others (6) aren't.
    You're right that it seems to freeze/beachball for 4-8 minutes and then usually goes back to normal.   Fortunately, it doesn't happen every day for me, but it is annoying when it does.
    I'm open to any suggestions.
    Mac Pro 2 x 2.66 Ghz 6-Core Intel Xeon, 16Gb RAM, Mac OS 10.7.2, MC6.0.1.1, NitrisDX [view my complete system specs]
