Latest post Mon, Aug 13 2018 1:34 PM by Terry Snyder. 7 replies.
  • Sun, Aug 12 2018 3:58 PM
    Encoding from Avid SAS on a non-MC machine
    I installed Squeeze on my non-Avid computer then tried to encode from an Avid same-as-source file exported from my MC system and copied to the non-Avid PC.   The resulting output screen is black (although I have audio.)   I realized I don't have the Avid DNxHD codecs installed on my non-Avid machine, so I'm assuming that's why Squeeze can't encode the same-as-source file. Embarrassed
    I can't find the link to install the Avid codecs on my non-Avid PC.   Would someone kindly point me in that direction?
    Terry
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Sun, Aug 12 2018 4:10 PM In reply to
    Re: Encoding from Avid SAS on a non-MC machine
    I've found a few links to download the free DNxHD codecs, but the links are very old.   Since I'm creating the same-as-source files in MC 2018.4, I assume I need a more updated download link?
  • Sun, Aug 12 2018 5:03 PM In reply to
    • cls105
    • los angeles
    • Posts 367
    • Points 4,785
    I never export using SAS quicktime anymore.
    Try AMA file export.  Its seems much more reliable to me.
    MC 2018.11, x299 7940x, 1080ti, 128gb ram, w10 pro (1803) [view my complete system specs]
  • Sun, Aug 12 2018 5:54 PM In reply to
    Interesting suggestion.   I will try it on my Avid workstation. But I still need the Avid Codecs on my non-Avid PC in order for Sorenson to work with files exported from Avid and then encoded with Squeeze on a different machine.  Especially since I record to an Atomos field recorder in DNxHD as my source material.
  • Sun, Aug 12 2018 6:22 PM In reply to
    I doubt the coded has changed much. But why not run your MC installer on the non-Avid machine? You’re free to install, even if you don’t activate, and the installer should give you the Avid codecs on that system.
  • Sun, Aug 12 2018 7:01 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 532
    • Points 6,770
    As far as I remember, the PE and LE codec packs are inside the  'Installers' folder when you download the main MC installer package.
    Just checked with the 8.8.4 installer on my home PC and they're present on this version.
    HP Z800, HP8760, SonnetFusion RAID, Mojo DX, Symphony 8.10, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Sun, Aug 12 2018 8:52 PM In reply to
    Desktop
    Corsair RM750X/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.4/Corsair 32G DDR3/PNY Quadro P2000D(390.77)/Samsung 850 Pro SSD(OS) 256 GB/ 2x2TB WD RE4@RAID 0/LG BH16NS40/W10 Pro 64bit/Media Composer Software 2018.11 with Symphony Option on Dongle/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Mon, Aug 13 2018 1:34 PM In reply to
    Thanks, guys.   I installed the Avid codecs on my non-Avid workstation and now Squeeze ecodes from Avid same as source files.
