Latest post Tue, Aug 28 2018 2:57 PM by André Milton. 1 replies.
Page 1 of 1 (2 items)
  • Tue, Aug 7 2018 3:02 PM
    • EndOfTape
    • Joined on Thu, Jul 22 2010
    • Posts 33
    • Points 395
    Regarding AD integration with CloudUX20186
    After running the avidctl script to create auth.yaml file. I can not see the groups defined in our AD. Are there any tools to help debug this?  MCUX at least had a test login tool. CloudUX20181 was successfully integrated  with this same AD
  • Tue, Aug 28 2018 2:57 PM In reply to
    Re: Regarding AD integration with CloudUX20186
    Hiya, there are a few tools you can use to test your AD setup - Apache Directory Studio is a good example.  You should make sure you've correctly set the DN and that the credentials you've provided are correct.  We plan on providing tools to test the AD config but they aren't available yet.
