Latest post Wed, Aug 8 2018 12:33 AM by Martin Fox. 1 replies.
Page 1 of 1 (2 items)
  • Tue, Aug 7 2018 9:02 AM
    • Fred42_p
    • Joined on Thu, Jul 26 2018
    • Posts 5
    • Points 65
    Stretched Aspect Ratio
    I'm trying to edit some footage that was originally from a dvd. The original file was Video TS, I converted the file into a MOV. format using windx dvd ripper .
    When I imported the footage into avid, the aspect ratio became stretched horizontally. I'd really appreciate any help and advice as to how I can sort this out.
    When I was importing the footage under the video resolution part I selected the DN X HD 120 option would that have contributed to the issue ?
    I'm using Avid medis composer 6.
    Thank you
  • Wed, Aug 8 2018 12:33 AM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 158
    • Points 1,605
    Re: Stretched Aspect Ratio
    Do you have frame flex on MC 6?
    frame flex enables you to adjust frame size aspect ratio etc
    right click on the clip, select source settings, select frame flex,
    if if not use your resize effect tool to shrink the horizontal dimension to attain the correct aspect, save the effect to a bin for re-use
    iMac Retina27 late 2017 4.5Gz i7 40GB AMD 8GB with Sata Raid OS 10.13.3 MC 2018.3 BMD mini monitor with Eizo monitor [view my complete system specs]
