Latest post Sun, Aug 12 2018 4:32 PM by Dr. Bane. 4 replies.
  • Tue, Aug 7 2018 1:03 AM
    • Dr. Bane
    • Joined on Tue, Aug 7 2018
    • Posts 3
    • Points 35
    MC First Exception Error
    I am attempting to launch MC First on Windows 10, and I keep getting an exception error immediately at launch:
    "Can't create a directory, as one of the folders in the path below has insufficient permissions., path:E:\Projects\Avid\myusername
    The Avid Projects folder is on an external F drive (F:\Projects\Avid\myusername), but it won't give me an option to
    change the path. I have to force close the program through Task Manager.
    How do I change the drive? The program launches, but it will not go past this point.
    I can send a screenshot if necessary.
  • Thu, Aug 9 2018 3:08 PM In reply to
    • Posts 9,469
    • Points 208,615
    Re: MC First Exception Error
    Dr Bane....
    The MC First installer should have installed the app on the internal drive in programs.  one thign you need to be aware of is, do not bury the app too far down in the drive hierarchy as that will cause an error.
    I would unistal the application unsing the uninstaller and then install again onto your C; drive ( internal ) and at the top level.
    AOL IM:  avidmarianna
    Skype: mariannamontague
  • Thu, Aug 9 2018 8:08 PM In reply to
    • Dr. Bane
    • Posts 3
    • Points 35
    The program is installed on the internal C: drive. I went ahead and uninstalled it and re-installed it just to be sure. I still get the same error. When I install, I'm not given an option of where to put the program, the installer does it automatically. I will try again, but the program is on the internal drive.
    CB
  • Sun, Aug 12 2018 2:55 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,561
    • Points 17,070
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Hi CB,
     Move these files Site_Attributes and MCState to a new folder, the file path is C:\Users\Public\Documents\Avid Media Composer\Settings report back.
    RalphC
    This is a test. Media Composer 8.8 w/Symphony option, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
  • Sun, Aug 12 2018 4:32 PM In reply to
    • Dr. Bane
    • Posts 3
    • Points 35
    Hi RalphC,
    Both of those files are located in that folder. Same exception error.
    CB
