Latest post Sat, Aug 4 2018 7:36 AM by Telegram!. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Aug 3 2018 9:45 PM
    Repositioning frame after SpectraMatte applied?
    Hi all-
    Got a bunch o' green screen interviews to swap the BG out on.  Sometimes I would prefer to noodle with the subject's position in the frame.  I'm getting the best key using SpectraMatte (per the suggestion of my other editor.  The Chroma Keyer isn't powerful enough to handle some of these keys).
    However, when I go to change the position in the frame I add 3D Warp... and I lose the entire key, it just goes right back to green.
    Any ideas?
  • Sat, Aug 4 2018 7:36 AM In reply to
    Re: Repositioning frame after SpectraMatte applied?
    chapmattman:
    Hi all-
    Any ideas?
    Sounds like you may be adding the 3D effect onto an existing SpectraMatte FX? Did you know you can access SpectraMatte within 3D Warp, using Foreground and it’s choice of Keys. Maybe try that...
