Latest post Thu, Aug 2 2018 3:34 PM by Telegram!. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Aug 1 2018 8:53 PM
    ALT click and drag
    Hi all-
    Can someone explain to me the difference between holding ALT and dragging (lasso'ing) clips to select them?  I often do the same thing and get two different results.
    When I hold ALT and lasso a group of clips on the timeline, my desired effect is to select all those clips, to be moved or deleted or what-have-you.  This happens around 50% of the time.
    The other 50% of the time, the EDIT POINTS on the group of clips within the lasso become selected.
    I'd love to know what is causing the difference in behaviors.
    Thanks!
    Chapman
  • Wed, Aug 1 2018 10:23 PM In reply to
    • Martin Fox
    • Joined on Fri, Mar 14 2014
    • Sydney Australia
    • Posts 218
    • Points 2,290
    Re: ALT click and drag
    I think it’s dragging to the right that selects clips, and dragging to the left that selects edits.
  • Thu, Aug 2 2018 7:37 AM In reply to
    Martin Fox:
    That sounds right.
    I was looking in Settings > Timeline > Edit which has some lasso-related items... including “Dynamic” which
    I just discovered and is a trip!
  • Thu, Aug 2 2018 2:01 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,486
    • Points 64,375
    Telegram!:
    Martin Fox:
    That sounds right.
    I can confirm that it works like Martin wrote.
    Telegram!:
    never noticed before, I might tinker with the settings myself, since they're so trippy!
    Symphony 2018.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Thu, Aug 2 2018 2:11 PM In reply to
    Yup, that's right.  Fun!
    How does Dynamic work differently?
    Chap
  • Thu, Aug 2 2018 3:34 PM In reply to
    Dynamic seems to highlight or ghost clips as you move mouse back and forth, up and down, so I would say it helps to visualize what will happen, or to preview with precision, before you let go of the lasso to select your clips.
    WHAT I WOULD GIVE to be able to Dynamic Toggle my lasso results in these 5 ways: Slide, Slip, Segment Highlight and OFF and also Last Trim.
