Latest post Fri, Jul 27 2018 1:33 PM by AntCaladine. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Jul 27 2018 10:57 AM
    • AntCaladine
    • Joined on Tue, Sep 11 2007
    • Stourbridge, UK
    • Posts 340
    • Points 4,295
    2018.7 creating hidden out point
    Most probably user error, so could someone point out or confirm similar bug.
    Drop a clip in source record monitor, mark an in point only. (for testing, easiest at the start)
    Move the play cursor (blue line) in source window to wherever, but not the end.
    Place clip on timeline using splice/overwrite.
    In previous versions this would put that entire clip on the timeline as the in point was at the start and there was no out point set, whereas 2018.7 is creating a hidden out point based on where that blue line cursor was left.
    So in my instance, instead of an 4 min clip going on the timeline, a 34sec clip has.
    Deleted the usual mcstate, site settings, diff user etc makes no difference.
    Its not doing in it 2018.4 which we've put back on our edit 1
    2x HP Z8 G4, 96GB ram, Win10 Pro 64bit, Nvidia Quadro P4000 8GB AMC 2018.12 1x HP Z820 16GB ram, Win10 Pro 64bit, Nvidia Quadro 4000 AMC 2018.11 2x Aja... [view my complete system specs]
  • Fri, Jul 27 2018 1:33 PM In reply to
    • AntCaladine
    • Stourbridge, UK
    • Posts 340
    • Points 4,295
    Re: 2018.7 creating hidden out point
    Have managed to get to the bottom of it.
    At looks of it, upon upgrade for 2018.4 to .7 for existing avid users on our suites it has enabled single mark editing in composer settings.
    Turning that option off, everything works as it should.
    Creating a new 2018.7 user has the option disabled by default, so must be a glitch in upgrade somewhere.
