Latest post Sun, Jul 29 2018 3:23 AM by John. 8 replies.
Page 1 of 1 (9 items)
  • Fri, Jul 27 2018 1:51 AM
    • John
    • Joined on Mon, Oct 15 2012
    • Boise, Idaho
    • Posts 189
    • Points 2,320
    Best codecs for You Tube
    Hello,
    I'm trying to export a video to be put on You Tube but my codecs are making everything look thinner and grainy.  I've tried H.264 and MPEG4.  Are there any others I should trying?
    Thanks in advance,
    John
    Avid MC8.9.3 iMac 27-inch, Late 2012 Processor 3.4 GHz Intel Core i7 Graphics NVIDIA GeForce GTX 680MX 2048 MB Software OS X 10.8.2 (12C2037) ... [view my complete system specs]
  • Fri, Jul 27 2018 4:25 AM In reply to
    • John
    • Boise, Idaho
    • Posts 189
    • Points 2,320
    Re: Best codecs for You Tube
    Should mention I have'nt been able to export with same as source.  That could be the problem.  When I do attempt it, I get this message
    Long GOP media can not be exported using same as source.  Please select a custom resolution or transcode to an I-frame only resolution instead.
    I have no idea what this means.
    Appreciate any help.
    John
  • Fri, Jul 27 2018 2:49 PM In reply to
    John:
    You should do a video mixdown first.   Then try exporting the mixdown track as a same-as-source.   If this works, there are some Sorenson MP4 pre-sets that are optimized for YouTube.
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Sat, Jul 28 2018 2:26 AM In reply to
    • John
    • Boise, Idaho
    • Posts 189
    • Points 2,320
    Thanks Terry.  What resolution should I use.  It has DNxHD 145 MXF selected but when I hit OK, nothing happens.
  • Sat, Jul 28 2018 6:33 AM In reply to
    • John
    • Boise, Idaho
    • Posts 189
    • Points 2,320
    Also, it is telling me that about 108820 MB are required
  • Sat, Jul 28 2018 2:40 PM In reply to
    Do a mixdown (both audio and video) and then make a copy of your sequence.   Open the duplicated sequence and delete all tracks except the mixdown tracks.   Then export as a same-as-source.  If the sequence is long, try exporting as a Quicktime Reference.  It will be faster and take up less space.   Then import the same-as-source or QT ref into Sorenson and transcode to MP4 for YouTube.
  • Sat, Jul 28 2018 5:15 PM In reply to
    Here's a link to Sorenson's Presets:
    https://support.sorensonmedia.com/customer/portal/articles/1425069-popular-and-customized-presets-for-squeeze
    Under MP4 Presets/Misc, there are YouTube 720 and 1080 presets.
  • Sat, Jul 28 2018 9:28 PM In reply to
    • John
    • Boise, Idaho
    • Posts 189
    • Points 2,320
    Before I can do that I need to figure out what is going on with my drive space.  Under target drive (for mixdown) I am getting the message 'All drives filtered out' and below it says 0 MB available.  Below resolution it says 'About 108820 MB required'
  • Sun, Jul 29 2018 3:23 AM In reply to
    • John
    • Boise, Idaho
    • Posts 189
    • Points 2,320
    Could it be that because I'm using my drive in source browser mode and not importing the footage the reason I'm having this difficulty?
