Latest post Tue, Jul 24 2018 10:48 AM by Gregor Cemeli. 4 replies.
  • Thu, Jul 19 2018 1:02 PM
    Is capture is finished ?
    Hello.
    I would like to know, is there a way, with Avid Interplay Web Services, to know if a record on an AirSpeed is finished ? (record in EWC started from Interplay Capture)
    I need to export a sequences with a segment of masterclip on it (Masterclip in EWC on the AirSpeed), and I have an error message if the capture is not finished.
    We already try to know, with "Frame Chase Expected Duration" and "Frame Chase Known Duration", but even when the record is finished we don't have the same value for these two attributes (sometimes on is bigger than the other, and sometimes not).
    Tnank you for your help.
  • Thu, Jul 19 2018 3:56 PM In reply to
    • Vadym
    • Joined on Thu, Apr 17 2014
    • Posts 210
    • Points 2,595
    • Avid Developer Moderator
      Avid Employee
    Re: Is capture is finished ?
    The correct way to check if master clip ingest is in progress is to read the "_OMM_MOB_COMPLETE" attribute which is set to 0 if ingest is not complete.
  • Fri, Jul 20 2018 10:07 AM In reply to
    Very good information.
    Is the _OMM_MOB_COMPLETE attribute readable via InterplayWS ? I dont see it in the Interplay WS Assets Attributes list.
    Is the Record Complete attribute equivalent ?
    Gregor.
  • Fri, Jul 20 2018 5:26 PM In reply to
    • Vadym
    • Posts 210
    • Points 2,595
      Avid Employee
    This is system attribute which is readable through IPWS. The attribute is not set for regular imports/ingests. Only EWC/Frame Chase workflows (should) create this attribute.
  • Tue, Jul 24 2018 10:48 AM In reply to
    Thanks, it works perfectly.
    Gregor.
