Latest post Tue, Jul 17 2018 4:03 AM by Telegram!. 2 replies.
  • Mon, Jul 16 2018 11:04 AM
    Symphony Wishlist
    The Symphony Corrector will soon be updated with masks. Hurrah!
    Here are other things I am hoping for:
    1. Work in 16 bit and using all the extended colorspace of the current Avid pipeline, currently a grade will clip outside 1-255.
    This would allow multiple corrections and Luts with virtually no chance of clipping. (See Note below.)
    2. Allow to load a LUT as a grade and export a grade as a LUT.
    3. Add curves for Saturation vs Lum, Saturation vs Hue.
    4. Allow all MC versions to correctly interpret Symphony grades.
    5. Access source settings from within CC.
    Note:
    Note that internally, levels are normalized to values between 0 and 1.  Black being 0 and white being 1. This normalization process makes it easy to handle media at 8, 10 12 or 16 bits.  Our internal format supports normalized values from -2.0 to 2.0 so nothing gets lost when you apply color transformations.  It might become out of the Legal range (0 to 1 in normalized values, 16-235 in 8 bit representation) but those values are still there.
    Symphony 7.06 OS 10.9.5 QT 7.6.3 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona 3. MC 7.0.6 OS 10.9.5 Mac Pro 5.1 2x2.97 6-core 14GB ram Aja I/O express, Apple... [view my complete system specs]
  • Mon, Jul 16 2018 2:32 PM In reply to
    Re: Symphony Wishlist
    David Yardley:
       Yes +1
    Currently, I need to add a LUT to log footage at the source level.  With several layers of effects added, MC becomes a bit sluggish...without LUT's, performance is fine.   So I'm hoping once LUT's are integrated into Symphony's CC, performance will improve.
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Tue, Jul 17 2018 4:03 AM In reply to
    +1
    also...
    Most cameras offer a version of “Sharpen”
    or “Noise Reduction” which can sometimes Soften an image.
    To match unmatched shots, that’s what I’d like to see in the Symphony CC toolset... or is it there already? Hi
