Latest post Thu, Aug 9 2018 6:36 PM by messyjesse. 39 replies.
Page 3 of 3 (40 items) < Previous 1 2 3
  • Thu, Jul 19 2018 6:53 PM In reply to
    • Posts 10,079
    • Points 216,475
    Re: Media Composer v2018.7 -- NOW AVAILABLE!
    Philo
    One thing I didnt ask you....   are you also using Pro Tools?  If so, users were advised NOT update to this release if you use the Video Satellite feature with Pro Tools.
    I am going to have your case looked at more closely....
    you can download 2018.5 from the download center - it is at the very bottom of the MC folder.
  • Thu, Jul 19 2018 11:41 PM In reply to
    No protools. Wacom tablet, premiere, fcpx, resolve studio, several 3D graphics programs.
    Avid Media Composer 2018.8, OSX 10.13.6. iMac 2017 Pro 1000 GB SSI drive with 8 TB Thunderbolt Raid drive, 16 GB memory. [view my complete system specs]
  • Sat, Jul 21 2018 2:34 AM In reply to
    After a couple uninstalls and reinstalls (using Avid apps) and removing some cache files, the problem persists. I downloaded MC 2018.5 and it too lags badly with playing - so it must be the OSX update itself that caused the problem (10.13.6). I discovered I can scrub the timeline my moving the mouse, but playing with hitting the play button, spacebar or jkl editing basically is so slow to make editing unfeasable.
  • Thu, Jul 26 2018 3:00 AM In reply to
    Hello :)
    Just popping my head in to say that I'm also unable to use this version, but not because of sluggishness. When playing down any timeline, this happens almost immediately...
    https://www.youtube.com/watch?v=GYTBiH5k8ec
    So I guess I'll be rolling back to .5 as well!
    I'm also seeing in other threads that people are talking about a 2018.7.1 patch? I am not seeing this patch in Application Manager?
    Hardware: 5K iMac (late 2015 17,1), 4 GHz i7, 32 GB, M395X w/ 4 GB, Promise Pegasus2 R4 in RAID 5 | Additional monitoring: 2.5K thunderbolt display, Dreamcolor... [view my complete system specs]
  • Thu, Jul 26 2018 7:47 AM In reply to
    • RobertM
    • Joined on Mon, Jan 20 2014
    • Posts 10
    • Points 95
    delete user / create new
    Alastair Tye Samson:
    Hello :)
  • Thu, Jul 26 2018 2:27 PM In reply to
    • Posts 10,079
    • Points 216,475
    Hello :)
    Head to the download center - log in to your My Avid and then click on the DL center and open the MC folder.  2018.7.1 is there.  It is also located in your MY Avid if your plan is still valid.
  • Thu, Jul 26 2018 9:46 PM In reply to
    RobertM:
    Thank you, RobertM, fresh user settings do indeed fix this problem!
    Marianna:
    Thank you for pointing me in the right direction! However, now that everything is going okay with fresh user settings I think I'll hold off unless any other problems pop up :)
  • Fri, Jul 27 2018 4:53 AM In reply to
    Ah, *** it... turns out this is still happening with fresh user settings!
    I'll try installing the patch over the weekend :)
  • Sat, Aug 4 2018 1:36 PM In reply to
    • Svenbox
    • Germany
    • Posts 233
    • Points 2,975
    Getting Segmentation fault often.  Might have something to do with Safari?
    When I change to Safari it crashes (not always). Can't figure it out, yet.
    Crashes also when I switch to other tools like Word.
    iMac pro, MC 2018.7.1 on 10.13.4., 32 Gb, 1Tb SSD, 12 Tb G-speed ext. RAID 1, [view my complete system specs]
    Wat soll dä Quatsch?
  • Thu, Aug 9 2018 6:36 PM In reply to
    2018.7.1 is still wonky, the patch hasn't fixed all the issues. Having very frequent dropped audio frames and timeline sluggishness, even when playing very simple sequences (like 1 track of audio only, for example). I'm going to downgrade back to 2018.5 for a second time, and wait for the next patch.
    I am on a 2017 iMac, 4.2 ghz quad core, 32 gb ram
