Avid is pleased to announce the latest release of Media Composer v2018.7 on July 12th, 2018. The software is available through My Avid, Avid Application Manager, or the Download Center (login and password required). You must have a current Support & Upgrade plan to run the latest software.+ OS SUPPORT:This release now supports macOS 10.13.5 (High Sierra) as well as 10.12.6 (Sierra), 10.11.6 (El Capitan), and 10.10.5 (Yosemite).
+ NEW FEATURES:- Live Timeline- 16K Project Presets- Resizable Composer Window- Full Frame Stereoscopic Support w/Avid Artist DNxIQ- Thin Raster Support with Open I/O Hardware- Exporting XDCAM OP1a Media- Support for NewTek NDI Video over IP....and several more!
+ DONGLE USERS:Please note that the sentinel drivers for dongles is no longer automatically installed. After you install MC, you must install the sentinel drivers from the /Applications/Utilities/Avid Utilities/Sentinel Driver folder.
+ NITRIS DX/MOJO DX USERS:Please note the DX driver is NOT automatically selected in the install process. Within the MC installer, when you get to Installation Type, be sure to select the Avid DX Driver under Media Composer Editing Application.
+ BUG FIXES:This release addresses 18 bugs since the last release, including:
- You could not successfully apply a Trim to Fill Timewarp effect on clips with FrameFlex.- Not all bins were indexed when you performed a search in the Find window.- When working with Spectramatte, the fixed aspect checkbox did not function for scaling. + FOR MORE INFORMATION:See the ReadMe or What's New documents published on the Knowledge Base prior to upgrading if you have any questions.If you have general issues with installing or running the release, post them here. If you think you have found additional bugs, please start a new thread.
Can't work with that version. When zooming timeline, it's dissapearing and appears a message.
Exception: CORE_SEGMENT_NOT_FOUND, classname:TLtrack, methodName:DrawSegDupZones
And it's depends from the height of video track. With narrow tracks everything is fine but with thick ones appears that bug.
Very glitchy so far, to the point of being unworkable.
I updated to 2018.7 and OS 10.13.5 last night. This morning, when I try to play in the source window my whole computer freezes for about 10 or 12 seconds. Background music stops, mouse freezes...then everything comes back. It happens irregularly, but frequently. No crashes yet -- but very very slow going. Grateful I don't have a deadline today.
messyjesse,
What kind of Mac are you using?
Same here. My CPU usage goes to max after 10 seconds or so and then avid starts dropping frames. Never had a problem before. Using an iMac.
2017 iMac, 4.2 GHz i7, 32 GB ram
AVID, could you tell me where to download an older version please. I can't edit with this one.
Old versions are in the Avid Download Center under Media Composer.
I found 2018.5 here:
http://esd.avid.com/ProductDownload.aspx?id=1917
Downgraded and everything is back to normal. Phew.
Me too. Downgraded, everything working fine.
I imagine the issue has something to do with the new live timeline features.
Hey everyone......
Please email me directly regarding the sluggishness. send the following in the email:
Subject: Sluggishness
Computer Type
OS (exact info)
RAM
Graphics
3rd party products and driver
Storage ( if shared storgae what kind and version of software )
Trying to get a handle on this
marianna
my system is iMac pro 10 core 64 ram
Media composer 2018.7 continuous hanging system even at the same playback
This version is not suitable for work.
