Latest post Fri, Jul 13 2018 8:18 PM by Marianna. 7 replies.
  • Wed, Jul 11 2018 11:29 PM
    Need help with media composer fist
    Hi everyone I wonder if anyone can help me.
    I work with pro tools and I want to try out media composer first to make a video since its AVIDs, but I cant make media composer work, I installed it and load it to the point it freezes just after It loads all components. It shows the main screen but It does not respond to mouse clicks and I have to kill the app abruptly
    this is my computer:
    intel core i7-2670qm 2.20Ghz
    RAM 8Gb
    NVIDIA GeForce GT 525M
    windows 10 professional
    with enough hard disk drive space to work.
    Is there any failure log?
    somebody that can help me?
  • Thu, Jul 12 2018 12:42 PM In reply to
    • Posts 10,089
    • Points 216,615
    Re: Need help with media composer fist
    Hello Elizabeth....
    Welcome to the forums and Avid.  There is a specific install when you have Pro Tools and Media Composer.  From the latest ReadMe:
    Compatibility with Pro Tools - General Co-Installation Notes Pro Tools refers to Pro Tools | First, Pro Tools, and Pro Tools | Ultimate.
    • You must uninstall all older versions of Media Composer | First or Pro Tools before installing newer versions.
    • You cannot launch both applications at the same time.
    • If you run into any issues, uninstall both applications and reinstall Pro Tools first, and then reinstall Media Composer | First.
    • When you uninstall Pro Tools, choose to uninstall just the application and not the audio drivers or the editing application no longer sees the devices.
    Report back
  • Fri, Jul 13 2018 2:41 AM In reply to
    Thank you Mariana
    I did what you said, I download the latest version of pro tools and uninstall both applications, reinstall Pro Tools first and then reinstall Media Composer | First. but sadly didn't work.
    Pro tools is working but media composer is not.
    Any other Idea?
    Does the media composer installation have a log report or something?
    Marianna:
    Hello Elizabeth....
    Report back
  • Fri, Jul 13 2018 2:37 PM In reply to
    • Posts 10,089
    • Points 216,615
    PC:  C:\ProgramData\Avid\Support\Logs
    Can you send them along?
  • Fri, Jul 13 2018 4:38 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,796
    • Points 19,830
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Hi Elizabeth,
       While your still getting the logs to Marianna.
    elizabeth.mariscal:
    Try launching MC|First using GT525M, IIRC intel core i7-2670qm 2.20Ghz has a built in Intel® HD Graphics 3000 which runs by default? check the FAQ below.
    http://avid.force.com/pkb/articles/en_US/faq/Media-Composer-First-Install-freezes-on-startup-project-window-is-not-visible-at-all
  • Fri, Jul 13 2018 5:17 PM In reply to
    Hi  Mariana
    thank you again.
    Here you can find the logs
    https://drive.google.com/drive/folders/1JpGaSvTcE7p3TaRjlqCD4TfJPo6ZD79d?usp=sharing
    Marianna:
  • Fri, Jul 13 2018 6:42 PM In reply to
    Hi Ralph and Mariana
    THANK You both!! the startup project window appeared and everything is working perfectly
    I opened the configuration panel for NVIDIA, 3d management, program configuration tab, and select Nvidia for avid media composer as a default graphic processor for the program, and finally !!
    Thank you!!
    I'm so happy!
    RalphC:
    Hi Elizabeth,
    elizabeth.mariscal:
  • Fri, Jul 13 2018 8:18 PM In reply to
    • Posts 10,089
    • Points 216,615
    Ha It was all RalphC
    You rock Ralph
    Only a forum post away and welcome to First!
