Latest post Sat, Jul 14 2018 3:25 PM by Telegram!. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Jul 10 2018 10:42 AM
    • damien78
    • Joined on Tue, Jan 7 2014
    • Geneva
    • Posts 22
    • Points 250
    Compensating delay of one track in an autosync group
    I have some video footages with a LTC audio track, which are autosynced with multiwaves files from audio recorders.
    One track of each multiwave file is a LAV track with a 19 ms constant delay (from a sennheiser AVX transmitter).
    Is there an efficient way to correct this delay inside AVID? Not a big deal, but if it can be done easily and reliably...
    Thanks !
    Media Composer 2018.12.1, w/Symphony/SS/PF options, MAC PRO 2013 3.5 GHz 6-Core Intel Xeon E5, ATI FirePro D500 3072 Mo, 32 GB RAM, MacOS 10.13.6, AJA... [view my complete system specs]
  • Wed, Jul 11 2018 4:05 PM In reply to
    Re: Compensating delay of one track in an autosync group
    I can suggest using an RTAS delay, which works on any edited clip, but over the entire track, once edited on the Composer >> Timeline.
    There may be other better options, including a sub-frame "slip" tool, but I'm not sure if it can work selectively  on your Lav in your multi-channel wav file
    But take a look at this.
  • Wed, Jul 11 2018 4:56 PM In reply to
    Does the RTAS delay effect offer a negative delay (its an advance that needed)?
  • Wed, Jul 11 2018 5:09 PM In reply to
    Pat Horridge:
    Nope, but it works (sort of) combined with a one-frame segment nudge.
    I'm now interested in coming up with a way to "bake in" such corrections into Groups, etc. using the new Slip tool, which is probably a whole lot better... if the workflow to do it can be simplified.
  • Thu, Jul 12 2018 3:23 AM In reply to
    The new Audio Sub Frame Slip function does not seem to allow individual channel slips. I imported an 8-channel Wav where only Ch1 needed slipping... but all tracks were affected. I suppose a workaround is to import/link a extra duplicate file, but mix and match before creating an AutoSync or GroupClip.
  • Thu, Jul 12 2018 9:02 AM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 549
    • Points 7,005
    Recently, there was a sneak preview of new MC features due to arrive before the end of the year.
    One of these new features was the ability to change a multicam / group clip after creation. Not sure if this includes autosynced groups, but it's a step in the right direction.
    To read the thread (with links to demos), see...
    http://community.avid.com/forums/t/184275.aspx
    HP Z800, HP8760, SonnetFusion RAID, Mojo DX, Symphony 8.10, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Thu, Jul 12 2018 11:04 AM In reply to
    Bruno M:
    'Thanks, Bruno, I recall you posting it.
    And that workaround idea above, about Grouping a Slipped clip with a 2nd import of the same clip, which is un-slipped.... I just tried it and in a quick test I found that a Group does not maintain the Slip adapter... even after refreshing the timeline sequence.Perhaps it is a different story with an AutoSync clip (which I don't normally use and didn't try).
    It's such a neat new tool.. Oh well, at least you can match-frame from the Groupclip back to the slipped masterclip and replace the sound on a preferred track (like the OP wanted to do on Ch1.) Then it appears on the timeline showing the Slip adapter...
  • Thu, Jul 12 2018 2:16 PM In reply to
    • damien78
    • Geneva
    • Posts 22
    • Points 250
    Thanks all for all the comments/suggestions.
    I was hopping for an "elegant" solution I missed, but it seems that there is not one yet. In my case, I think it'll be better to handle the compensation of the delay in Pro Tools, when needed only.
    Hoppefully Avid will address that in a near future, but to be honest, I'm not so optimistic: a lot of features announced last year, but not that much delivered yet. I don't get for example the audio slip in source settings as you can't do a track by track settings.
  • Thu, Jul 12 2018 6:04 PM In reply to
    damien78:
    You’re welcome.
  • Sat, Jul 14 2018 3:25 PM In reply to
    I’d like some help from anyone interested in fully learning the particulars of the Sub Frame Audio Slip adapter.
    I start with the online MC feature documentation, then hope to go forward from there with examples and any details.
    • I am interested in how a Slipped masterclip behaves if it becomes (or pre-dates) inclusion in a Group clip, AutoSync clip.
    (based on very quick tests, it seems there are limitations (in v2018.4)
    • I want to get a real handle on how Sub-Frame Audio slipping is best applied for clips already on a Composer Tineline.
    If this is the case, can we apply e.g., a +19ms Slip to one timeline clip, but also apply a -12 ms Slip to a different Timeline clip, from the same masterclip?
    Also: Can anyone confirm that an Audio Slip adapter can be saved to a Bin? and therefore able to be applied to onto multiple highlighted segments? Can a timeline with multiple highlighted segments get Sub Frame Slipped?
    Do I need to have initially applied some kind of Sub Frame Audio Slip adapter from the Bin/ Source Setting (prior to timeline editing) in order to have the ability to do any Sub Frame Audio Slipping on a Timeline clip from it?
    Thanks to any interested editors, Avid engineers, etc. for any responses....
