Latest post Fri, Jul 6 2018 4:58 PM by camoscato. 4 replies.
  • Tue, Jul 3 2018 7:31 PM
    • bushfilm
    • Baton Rouge, LA
    • Posts 537
    • Points 7,235
    Import options
    Hi all,
    i have set up a 1080p30p project and upon trying to import the footage, I can only select Dnx 145 as the lowest option setting. How can I choose a lower setting, since I am going to have to up-rez ;ater, I might as well keep the storage space down?
    Any suggestions?  Thanks.
  • Wed, Jul 4 2018 6:00 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,479
    • Points 64,270
    Re: Import options
    Hi there, what if You link and transcode instead importing?
    Symphony 2018.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Fri, Jul 6 2018 4:04 PM In reply to
    • bushfilm
    • Baton Rouge, LA
    • Posts 537
    • Points 7,235
    Re: Import options
    Ooops...never mind. I discovered that you can select other import settings when using "Batch Import" and, for some unknown reason, once I selected Dnx 45, I was also able to select it in the plain "import" setting.
    Thanks, hope this helped someone.
  • Fri, Jul 6 2018 4:20 PM In reply to
    • bushfilm
    • Baton Rouge, LA
    • Posts 537
    • Points 7,235
    Re: Import options
    I am just old-fashioned I guess; I like the media on a physical drive, not just linked, because I've seen what happens when a very sophiscated system goes south. It can get ugly. So I like to know that there is real media, not just a link which might get attacked by Russian bots or something,
  • Fri, Jul 6 2018 4:58 PM In reply to
    Re: Import options
    bushfilm:
    If you link and then immediately transcode to whatever resolution you want, you'll have media on a physical drive. The advantage is transcoding goes faster because it uses more processor power - it was introduced more recently, and takes advantage of newer technology.
    Rather than thinking of it as linking vs importing, think of it as linking & transcoding vs importing - two ways to get to the same result.
    Media Composer 2018.12 w/Symphony/SS/PF options, HP Envy 17t-j100 Quad Edition laptop, Windows 10 Pro, Intel Core i7 2.4GHz, 16 GB RAM, nVidia GeForce... [view my complete system specs]
