Latest post Sat, Jul 14 2018 12:49 AM by JCBond. 4 replies.
  • Tue, Jul 3 2018 12:23 AM
    • Thomas
    • Joined on Sun, Feb 23 2014
    • Cologne
    • Posts 34
    • Points 475
    render transitions of stacks over more layers from the buttom to the top and not inverse
    yes I want exactly this, that avid starts to render transitions of an effect pack over more layers from the ground to the top. Because right now it starts from the top and wasting a lot of time and performance.
    Z840, Win7Pro, 32GB RAM DDR4, NVIDIA Quadra K4200, Dual Intel Xenon E5 - 2650v3 2.3 2133 10Core / Macbook Pro Retina, MAC OS 10.10.5, 2,8 GHz Intel Core... [view my complete system specs]
    Thomas Poerschke, Editor & Colorist
    ColorGrading.TV @ MMC Studios Köln, Am Coloneum 1, 50829 Cologne, Germany
    web: www.colorgrading.tv
  • Thu, Jul 12 2018 8:52 AM In reply to
    Re: render transitions of stacks over more layers from the buttom to the top and not inverse
    The result of this would be concatenation, and in many situations produce banding where a clip is re-rendered several times with level changes to the possibly 8 bit render codec. Rendering top down will calculate the end result of any level changes in 16 bit (12bit for CC) and render.
    Symphony 7.06 OS 10.9.5 QT 7.6.3 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona 3. MC 7.0.6 OS 10.9.5 Mac Pro 5.1 2x2.97 6-core 14GB ram Aja I/O express, Apple... [view my complete system specs]
  • Thu, Jul 12 2018 9:04 AM In reply to
    • Thomas
    • Cologne
    • Posts 34
    • Points 475
    Ok, I undersatnd. But then I suggest to make a user-setting available, so the user can deside between performance and quality.
    Thanks for your help
    Thomas
  • Thu, Jul 12 2018 9:20 AM In reply to
    Thomas,
    Quality first. ;)
  • Sat, Jul 14 2018 12:49 AM In reply to
    • JCBond
    • Joined on Sat, Mar 11 2006
    • Van Nuys CA, USA
    • Posts 109
    • Points 1,145
    I will caution that rendering from the bottom up, even though it will be faster it WILL result in a lower quality render.
    If you really want to do this, open the console and enter the following command:
    ToggleTrackRenderingOrder
    This is a toggle so it will change between doing it from the bottom to the top or from the top to the bottom. This command will also PERSIST, meaning it will be remembered on that machine between launches of the software.
    System 1: Symphony Nitris DX - HP xw8600 8xCores - Windows 7 SP1 64 bit. System 2: Symphony Nitris DX - HP xw8600 8xCores - Windows 7 SP1 64 bit. System... [view my complete system specs]
