Latest post Sun, Jul 1 2018 10:57 AM by David Yardley. 6 replies.
Page 1 of 1 (7 items)
  • Sat, Jun 30 2018 6:23 PM
    • Bobster
    • Posts 12
    • Points 150
    Naming your auto-sync clips
    I haven't been doing log work for a long time, now I am sitting with a low budget short film so I need to refresh my logging info :)
    I want to do the best logging workflow possible, so that the onlining at the end will be easypeasy.
    After I autosync my clips, how important is the naming?
    Should I give it the transcode video file's name? Or the original video file's name? And then make a column with scene & take nr.
    Or should I just name them how I want? as when I match frame the original name comes up anyways. I just donøt know how the onlining will work later on.
    I used AMA to input my files. But as the camera resets the file numbers each time, there are a lot of files with same number.
    Thank you for any usefull tips!!
    Media Composer 2018.5.0 / Tower MAC High Sierra 10.13.5 / Processor 3,5 GHz 6-Core Intel Xeon E5 / Memory 16 GB 1866 MHz DDR3 [view my complete system specs]
  • Sat, Jun 30 2018 6:38 PM In reply to
    Re: Naming your auto-sync clips
    Online/conform is done with source/tape name and timecode. Name the synced clips any way you want.
  • Sat, Jun 30 2018 6:53 PM In reply to
    • Bobster
    • Posts 12
    • Points 150
    Great! I thought so but as my info in TapeId is empty, I was a bit unsure. I guess source path is also good enough.
    Thank you :)
  • Sat, Jun 30 2018 8:05 PM In reply to
    Look for an entry in either 'Tape' or 'Source File'. If you have neither, there will be trouble.
  • Sat, Jun 30 2018 8:16 PM In reply to
    Many Post houses enter the source folder name as the TapeID as a precaution. But it shouldn't be needed.
  • Sun, Jul 1 2018 4:34 AM In reply to
    • Bobster
    • Posts 12
    • Points 150
    I have source path and source file info. Thanks!
  • Sun, Jul 1 2018 10:57 AM In reply to
    A quick way of namimg the clips is to, before syncing, duplicate the sound recordists slate names (which are usually in the first column of the imported sound files to a custom column you have created, (command D) Then overwrite the clip names with these slate names after syncing. (command D)
    If the sound recordist is reliable then it saves the AE/you a bunch of work.
    Symphony 7.06 OS 10.9.5 QT 7.6.3 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona 3. MC 7.0.6 OS 10.9.5 Mac Pro 5.1 2x2.97 6-core 14GB ram Aja I/O express, Apple... [view my complete system specs]
