Hello hive mindIm having some performance troubles with my Avid machine and hoping some technical bods could give me some direction in troubleshooting/rectifying the issue.Im an AE on a BBC drama, I'm currently looking after a (qualified) Z820 + Nitris DX setup, where we have three suites on an Isis 5000.Im having troubes with my machine in particular. Avid is generally very sluggish - scrubbing up and down timelines is clunky, simple operations like marking/trimming/dragging are often accompanied by a second or two delay, as is stuff like renaming items in bins, switching smart tools, drawing shapes etc. Its almost as if there's a cyclical lag - every few seconds the interface will lock up whatever I might be doing.I updated my OS to Windows 10 and upgraded to MC 2018.5 a couple of weeks ago to try and recitify the issue and at first, it seemed to have done the trick. However I think its gradually resorted back to the previous performance woes.Interestingly, the same physical setup next door, albeit on Windows 7 and running 8.5.1, has none of the same issues - that Avid is smooth and snappy. So I'm hoping this is a configuration issue on my machine.Ive done the usual cohort of tests - defaulting user settings, trying a new project, running ASDT, and nothing's made a difference. Short of cloning next door's HDD and going from there Im not sure what to try next.Any ideas?Many thanks!
There is an interesting note in the z820 configuration guide about onboard NIC choices. If the system specs in your signature/profile are accurate, it's possible you may be using an unqualified NIC if you chose the wrong onboard adapter.
See this note:
Important Note regarding ISIS Connectivity based on CPU / processor generation: - The Z820 has 2 embedded NIC ports (82574L and 82579LM). - If your Z820 is configured with any of the new generation V2 CPU choices then both NIC ports can be used for ISIS 5000 / 7000 connectivity. - If your Z820 is configured with any of the original generation CPU choices then only the 82574L NIC port can be used for ISIS 5000 / 7000 connectivity.
and the source document here:
http://resources.avid.com/supportfiles/config_guides/AVIDHPZ820ConfigguideRevF.pdf
additionally, what version of ISIS/Nexis Client and server software are you running?
Dave
"A very big network"
Hey, thanks for the response
The machines have each got a dedicated Intel PRO 1000 PT for Isis connectivity. These are in slot 3 - so I think that's on spec?
We're using Isis server 4.7.7.16070, and client 4.7.11.16275.
Cheers
Hmmm, the pro 1000 should work. Have you run the nexis client profiler to check driver versions and send/recieve buffers?
I would also try using nexis client manager v7.11 or newer on the win10 machine. The NEXIS v2018.5 documentation says system directors v4.7.5 and higher are supported with the current client manager release.
edit: you may also want to verify that your BIOS version is updated and the settings match the config guide. One thing I have found in the z series BIOS is the need to disable PCIe performance mode for some cards.
I'd extend those trouble shooting tests.
Create a local project and test that using shared media.
Then try a local project with locally copied media.
Broadcast & Post Production Consultant / Trainer VET
The slowdown on 820 sounds familiar, does the amount of GB's in your attic have any impact on the slowdown? I've learned to rename my Unity Attic folder from time to time...
-Telegram!
Pat Horridge: I'd extend those trouble shooting tests. Create a local project and test that using shared media. Then try a local project with locally copied media.
Hello
Sorry for the slow reply... my workload quickly ramped up and I had to suspend testing. Have recently got back to it tho, and Im happy to say, your suggestion led me to finding the solution!
As the assistant, Im the point of ingest of rushes, and as such have hundreds (2 series worth of material!) of Avid MediaFiles folders on the ISIS associated with my computer's name, each containing the .db file which (I assume) my machine perpetually scans. This, it seems, has a major impact on the performance of Avid; the constant 2-3 second delays with creating/renaming bins, scrubbing around timelines, making edits etc etc... a major headache to say the least.
So the simple fix for now is - rename my machine, thus breaking that relationship with the databases.
Performance is back to normal. I'm kicking myself for not realising this weeks ago - it should be obvious...
To any other assistants reading this... on a big project its wise to come up with a renaming convention for the media folders to keep them from taking your computer's name. Its best to do this at the point of ingesting the rushes, or as soon as you've scanned the mxfs - before it goes into use for the edit - otherwise you'll get angry editors knocking on your door.
Pat - you are amazing!
Sion.... glad it finally got sorted. This is good information for a tech note for the Knowledge Base. Im going to do one today so the next person doesnt get stuck
Twitter: avidmarianna
www.avidcustomerassociation.com | Connect 2019 | April 6-7 | Aria, Las Vegas, NV
Marianna: Pat - you are amazing! Sion.... glad it finally got sorted. This is good information for a tech note for the Knowledge Base. Im going to do one today so the next person doesnt get stuck Marianna
Thanks Marianna - great idea! If you'd like me to provide more details with the specific workflows.... those that I should've been adhering to ... then let me know!
Sion
That would be amazing... can you email them to me?
Marianna: Sion That would be amazing... can you email them to me? Marianna
Sure, no probs Marianna, I'll get that to you asap
