Latest post Thu, Dec 6 2018 9:08 PM by Edward Retamal. 7 replies.
  • Thu, Jun 21 2018 8:58 AM
    • AlexisK
    • Joined on Thu, Jun 21 2018
    • Posts 4
    • Points 70
    Flickering/Jumping SubCap on Composer 2018
    Hi everyone !
    I'm on a documentary feature film in which we need english subtitles to broadcast it before making the final subtitles. It's edited on the version Avid Media Composer 2018.4.0.
    The editor used a LUT 3D as a specific video track on the whole timeline, and above stand the SubCaps track.
    In a inexplicable way, some of these subcaps are shaking, even jumping (like briefly changing position from down to middle screen, for about 1 frame time)... and it's random - or more precisely, some of them are jumping, then I replace it by another bit of SubCap, it stops, then it begins again...
    I tried to invert tracks (LUT/Subs) and it changes the moments of jumping, but doesn't cancel it !
    (For sure I already checked that there wasn't any keyframe on the subcaps position... I also tried to make a video render before screening... every move seems to change something, but everytime in a random way)
    Thanks a lot !
    A
  • Tue, Sep 4 2018 5:18 PM In reply to
    Re: Flickering/Jumping SubCap on Composer 2018
    Media composer 2018.7.1, same problem.
    Did anyone find a solution fo solving this problem?
  • Wed, Sep 12 2018 8:31 PM In reply to
    • AlexisK
    • Posts 4
    • Points 70
    Still no... The only one I got is to make an export, then go back on an older version of Avid and make them there...
  • Sun, Sep 23 2018 9:02 AM In reply to
    I found the solution for this bug. I observed that it didn't flicker when I have 2 raws in subcap, it is flickering only when I have only one, so on the empty row if you press space ( like an ascii invisible character) it solves the problem.
  • Mon, Sep 24 2018 8:21 PM In reply to
    • Posts 10,023
    • Points 215,770
    Alex and Gabi....
    I am having support check this for you both.....
  • Fri, Oct 26 2018 12:40 PM In reply to
    • Tim
    • Joined on Mon, Sep 12 2016
    • Posts 9
    • Points 125
    YES! That works like a charm. Thank you so much for this workaround. I was starting to go crazy.
    Why is this still not fixed?!
    AVID MC 2018.9 symphony option / Blackmagic Intensity Pro 4K / Intel Core i7-7700K @ 4.2ghz / 32 gb ram / NVIDIA GeForce GTX 970 / Windows 10 pro / [view my complete system specs]
  • Fri, Oct 26 2018 1:12 PM In reply to
    • Posts 10,023
    • Points 215,770
    Tim:
    Because the engineers havent pin pointed exactly what in code is causing it.  They are working on it though.
  • Thu, Dec 6 2018 9:08 PM In reply to
    Still toruble shooting this issue, having the 2 rows in subcap and it being renedered is the fix?
