Latest post Sat, Jun 16 2018 2:14 AM by touviere7. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Jun 12 2018 10:47 PM
    • Mike Milo
    • Coral Springs, Florida, USA
    • Posts 72
    • Points 980
    Adapters
    I've been noticing adapter icons on my timeline but not all the time. What is an adapter and what does it do? I'm wondering why I don't always see one.
    HP Z820 Dual Xeon Processor running Media Compposer 8.8 and Nitris DX. [view my complete system specs]
  • Tue, Jun 12 2018 11:36 PM In reply to
    Re: Adapters
    Did you apply a LUT to the clip?  To log footage, for example?
    MC 2018.4 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system drive... [view my complete system specs]
  • Tue, Jun 12 2018 11:53 PM In reply to
    • Mike Milo
    • Posts 72
    • Points 980
    Re: Adapters
    No.
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,623
    • Points 60,385
    Re: Adapters
    Mike Milo:
    There are three types of adapters used to conform your clips to the timeline format. These are color, spatial and temporal. If you put a clip on the timeline that has a different frame rate or interlaced makeup then MC will place a temporal adapter on the clip. This adapter can be promoted to a full Timewarp effect for special treatments. If your clip varies in color space or has a LUT, then a color adapter is applied. If it's resolution differs, a spatial adapter is applied.
    i may have a detail incorrect here and there but this is the general idea. Hope this helps.
    Camera(s) PXW-X70, HDR-FX1, Hero 6 Black | MC 18.12.1 | QT 7.7.9 | Continuum 2019 | Sapphire 2019 | Mocha Pro 2019 | Titler Pro 6 | Windows 10 Pro x64... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Wed, Jun 13 2018 6:59 AM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 469
    • Points 5,550
    Re: Adapters
    and sometimes these adapters will disappear with rendering like elusive pokemon.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Wed, Jun 13 2018 4:01 PM In reply to
    Re: Adapters
    Go to the clip in the timeline with the adapter and enter effects mode.   That should tell you what the adapter is and give you the option to adjust the parameters.
  • Thu, Jun 14 2018 11:58 AM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 916
    • Points 11,725
    Re: Adapters
    Lukas Boeck:
    Lukas,
    render a clip in the timeline converts this clip to the project format. Therefor a previously present temporal frameflex icon wil be deleted with the rendered clip. No miracle!
    Joachim
    Joachim Claus
  • Fri, Jun 15 2018 10:35 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 469
    • Points 5,550
    Re: Adapters
    Joachim Claus:
    render a clip in the timeline... No miracle!
    remind me to never debate santa claus with you.
  • Sat, Jun 16 2018 2:14 AM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 591
    • Points 6,695
    Re: Adapters
    Lukas Boeck:
    Joachim Claus:
    symphony 2018.12.1 - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (411.63) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2 - MSI... [view my complete system specs]
