Latest post Thu, Jun 21 2018 9:52 PM by ronn. 7 replies.
  • Mon, Jun 11 2018 6:59 PM
    • ronn
    • San Diego
    • Posts 991
    • Points 12,445
    "converting 436M closed caption data"????
    I now see "converting 436M closed caption data" when I double click on a file that has been linked. Whaaaat?
    Media Composer 2018.9 with Intensity Pro 4K, Lenovo P500, Win-7 64 Prof. 16GB RAM, Nvidia 2200, Sony FS7, EX1, Ninja Assassin, Came-TV Mini2, Harley Dyna... [view my complete system specs]
    Ronn Kilby
    San Diego
  • Mon, Jun 11 2018 8:39 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,572
    • Points 45,875
    Re: "converting 436M closed caption data"????
    It means that there's a SMPTE closed caption track in the video. It could just be an empty track. I've never come across a case of embedded CC like that, so I don't know if it will create a separate file for the closed captioning. In any case, embedded CC ends up on a data track. If you have a TV connected using something loke a BMD or Aja card, then you might be able to display the CC on that.  I don't knoiw if it will display in a monitor.
    Dave S.
  • Mon, Jun 11 2018 8:56 PM In reply to
    • ronn
    • San Diego
    • Posts 991
    • Points 12,445
    This is original field material straight out of my FS7. It's 4K XAVC-I. It contains no SMPTE CC track. Linking from XROOT folder. Each clip takes time to "convert" when I click to view, or transcode. I do not see any separate files created anywhere.
    Ronn Kilby
    San Diego
  • Tue, Jun 12 2018 12:51 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,572
    • Points 45,875
    Interesting. Media from the FS7 does have a data track, but it's metadata about the clips, not closed captioning. This may be a bug. Other FS7 owners will need to confirm this.
    Dave S.
  • Thu, Jun 21 2018 7:26 PM In reply to
    CONFIRMED Yes I have experienced the exact same issue.  It must be confusing some part of the FS7 metadata with CC data.
    All PC - 11 MC/Symphony Nitris DX 2018.1 - Interplay 3.6/90TB Mirrored Avid ISIS 5500 [view my complete system specs]
  • Thu, Jun 21 2018 8:06 PM In reply to
    • ronn
    • San Diego
    • Posts 991
    • Points 12,445
    Marianna - can you escalate? Definitely a bug that was not in previous versions.
    Ronn Kilby
    San Diego
  • Thu, Jun 21 2018 8:22 PM In reply to
    • Posts 10,284
    • Points 219,195
    Ronn
    Sure can but your spec's are old right?
    what MC version
    OS version?
  • Thu, Jun 21 2018 9:52 PM In reply to
    • ronn
    • San Diego
    • Posts 991
    • Points 12,445
    I was talking about 2018.x - I since rolled back to 8.9.x when I had this problem. OS Win7 prof.
    Ronn Kilby
    San Diego
