Latest post Wed, May 30 2018 7:16 PM by TyrellDec. 2 replies.
  • Wed, May 30 2018 7:32 AM
    • TyrellDec
    • Joined on Tue, Jul 22 2014
    • Posts 2
    • Points 20
    Updating record using AXF in Metadata dropfolder
    Hi Forum,  I'm a newbie to Avid MAM and I've been trying to update assets using AXF files via the dropfolder.   When I submit the AXF using the MAM Desktop "Import AXF" it updates the asset as expected. When dropped into the watchfolder it creates a new asset with a new GUID,  ignoring the GUID in the AXF file.
    Also,  is there a way to add locators (makers) in the AXF ?
    Two question,  any help will be much appreciated.
    Declan
    As simple example AXF
    <?xml version="1.0" encoding="utf-16"?>
    <!-- Simply change the comment and drop into WatchFolder\WatchServiceMamImport\WatchFolder\VIDEO\METADATA -->
    <AXFRoot>
      <MAObject type="default" mdclass="VIDEO">
        <GUID dmname="">201805270958141192168254064005056B4416A0000013292B00000D0D000024</GUID>
        <Meta name="COMMENT" format="string">Running AXF UpDateMeta from watchfolder</Meta>
       </MAObject>
    </AXFRoot>
  • Wed, May 30 2018 2:30 PM In reply to
    • Julius Klingel
    • Joined on Fri, Feb 15 2013
    • Kaiserslautern, Germany
    • Posts 4
    • Points 40
    • Avid Developer Moderator
      Avid Employee
    Re: Updating record using AXF in Metadata dropfolder
    the import process uses the EXTERNAL_ID attribute to identify the asset.
    So for example if you modify your AXF slightly so that it looks like this:
    <AXFRoot>
        <Meta name="EXTERNAL_ID" format="string">MyGreatAsset</Meta>
       </MAObject>
    </AXFRoot>
    You can use it to update your asset.
    If there is no EXTERNAL_ID present the import uses the Filename (including extension) as EXTERNAL_ID for the created asset.
  • Wed, May 30 2018 7:16 PM In reply to
    • TyrellDec
    • Posts 2
    • Points 20
    Thanks so much Julius.
