hello,
I strat with MC 2018-5, but the frame flex don't run correctly. I use PC.
When I want change the frame flex from 16/9 to 2.1 , I can see the grid changing in 2.1 but no black mask, the result don't change. I think is a bug with this news version.
Please help me !
Thank's
Christophe
What OS?
This is weird.... so you see the green dot showing that FrameFlex is in action and correctly sets the aspect ratio on the clip in the sequence?
What happens if you update the sequence by right-clicking on the sequence, then selecting Refresh Sequence -> Aspect Ratio and Reformatting Options?
Twitter: avidmarianna
www.avidcustomerassociation.com | Connect 2019 | April 6-7 | Aria, Las Vegas, NV
Hi Marianna
I've the same issue here. Just tested 2018.5 on OS X 10.12.6 and 10.13.4.
Frame Flex Letterbox/Pillarbox setting on AMA Links, Masterclips or Subclips does not apply in source settings window, source nor at record monitor. The grid looks correctly but no black bars are shown. Scale, Center & Crop seems to work.
Issue exists on existing projects or newley created ones. Also creaed a new user settings, it doesn't help.
Source Setting Frame Flex is applied to clip in timeline and effect symbol showed correctly (green dot). Changing in effect editor does also not as well as refresh sequence does not help, bars are not shown at all.
Best,Norbert
Zebra and Gorbi
I have created a case on this # 03492191
Support will get on it asap.
Hi Marianna,
Please see this:
MCCET-2462 | MC - FrameFlex bug (Slam Disques) [Case : 03474811]
Thanks!
Helpyou: Hi Marianna, Please see this: MCCET-2462 | MC - FrameFlex bug (Slam Disques) [Case : 03474811] Thanks!
Yes should have caught that. Fixed in 2018.5.1 which wasnt released but will be out in 2018.6 this month.
Great! Thanks a lot for your fast reply. Hope 2018.6 will be released soon since we are setting up all editing workstations at our school in the next few days.
Best,gorbi
I have the same problem!
2018.7 is coming.......
Has this been solved in Version 8? I have UHD and 4K footage that I have AMA'd in a 4K flat project and we are delivering in 1.85 and some of the footage looks stretched Vertically at points and some Horizontally, as if the frame flex isn't working right.
David,
This came about in 2018.5 and was fixed in 2018.5.1 and higher.
If you are seeing this in an earlier version then I suggest you get a case going with support so they can look at it.
