Latest post Tue, May 15 2018 8:13 AM by ShadenFreude. 3 replies.
  • Mon, May 14 2018 9:34 AM
    Avid on Windows 10- Slow read from Isis
    With the prospect of having to move to Windows 10, I have loaded it on a Z440 and a Z420 with Nexis client 7.11.0.8 and connected to an Isis 5000.  Running Pathdiag to test network speeds, I get full 100MB/s write to the Isis but I only get 16MB/s reads.  I have changed the drivers, swapped NICs  anything I can, and I still get a very low read speed.  There was W7 on the towers before I put W10 on, so I doubt it is hardware.  All Avid recommendations have been followed, Firewall, TCP tuning etc.  Anyone else out there would like to do a test to see if they get the same?
    PS. the only reason I noticed this is because I was doing some multicam tests to see if the towers and GFX cards would cope with a forthcoming job and in 9 camera mode, there was a lot of frame drops due to low bandwidth. I did get 40MB/s before changing drivers which seemingly killed the speed a bit more. Further investigation highlighted the issue.
    Normal 0 false false false EN-GB X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri",sans-serif; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;}
    MC/SN 2018.6+7+8+9 x 15 Z400/420/440 PC's 2 x Mac, 4 x PT 12.8.1 HDX all on PCs. [view my complete system specs]
  • Mon, May 14 2018 1:17 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 298
    • Points 3,450
    Re: Avid on Windows 10- Slow read from Isis
    what NICs are you using?  how are you configuring pathdiag? what version of system director software is your ISIS5k running?
    I have a fleet of z440s (and 420s before that) which never showed signs of network issues in ISIS or Nexis client. z420s hadintel PRO 1000 PCIe cards, z440s are using the onboard NIC. Win10 or Win7 pro x64.
    Attaching images to show a zone3 z440, using the onboard NIC in Win10, testing against a 4-engine ISIS 7k. System directors and firmware is 4.7.10, client is 2018.3, but the results are identical to 7.11 and 7.9
    Here are the pathdiag test settings
    Here are the pathdiag test results
    Dave
    "A very big network"
  • Mon, May 14 2018 3:25 PM In reply to
    • NYnutz
    • New York City
    • Posts 298
    • Points 3,450
    also forgot to ask: what is the network topology? what kind of switches are you using?
    Dave
  • Tue, May 15 2018 8:13 AM In reply to
    I am using a Force 10, configured correctly, I've tried both NICs on the Z440(the second being a PRO1000), configured pathdiag just as your image above.  Rebuilt one of the Z420 with w10 X64 and disabled all updates in gpedit straight after install and so far all is working.
