Latest post Sun, May 13 2018 8:58 PM by NYnutz. 1 replies.
Page 1 of 1 (2 items)
  • Fri, May 11 2018 10:22 PM
    • CIR
    • Joined on Fri, May 11 2018
    • Posts 1
    • Points 15
    Exporting Sequences with H.264 clips AMA's with Avid Generic Plug-in Hangs Forever...
    Exporting Sequences Same As Source with H.264 clips AMA's with Avid Generic Plug-in Hangs Forever... even if only the audio from the clip is used in the sequence.
    But if the same clips are AMA'd with the QuickTime Plug-In, then the export works fine.
    The Avid Generic Plug-in identifies the clips as AVC Long-GOP Main, while the Quicktime PlugIn idenfies them as H.264
  • Sun, May 13 2018 8:58 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 298
    • Points 3,450
    Re: Exporting Sequences with H.264 clips AMA's with Avid Generic Plug-in Hangs Forever...
    same-as-source exports generally don't work with codecs you can't write *TO*. Recomend using a custom quicktime export to DNxHD/HR or even better, use AMA file export to MXF OP1a to DNxHD/HR. Use the hi-rez file to generate H.264 in an external app: ffmpeg, media encoder, etc...
    Dave
    "A very big network"
