Latest post Fri, Jan 18 2019 6:48 AM by Job ter Burg. 4 replies.
  • Fri, May 11 2018 11:06 AM
    • mecom
    • Joined on Thu, Feb 22 2018
    • Posts 4
    • Points 50
    Quicktime reference files show black in Adobe Media Encoder
    Hello,
    I am aware that it is likely to be an issue of Adobe Media Encoder, however I want to ask here too because knowing if other users encounter the same issue might help to isolate the error:
    We often use Quicktime reference files, and suddenly no one could be interpret correctly by Adobe Media Encoder. It only shows black, but gives no error message. It encodes without a warning, but the result is a encoded file with correct audio but black picture. Selecting or deselecting the option 'use Avid codes' changes nothing.
    As there were numerous updates both from Adobe and from Avid, I cannot narrow this down to a certain time.
    Thank you
  • Fri, May 11 2018 11:16 AM In reply to
    • GT
    • South Africa
    • Posts 386
    • Points 4,215
    Re: Quicktime reference files show black in Adobe Media Encoder
    mecom:
    The latest version of Adobe Media Encoder (2018) no longer supports Quicktime Reference Files. A work-around is to install the 2017 version as this still works.
    MC Ver 8.7, Intel Core I5, NVidia Quadro FX 570, 16Gb Ram, 250 Gb system drive, 2 Tb Render/Media drive, Windows 7 64bit Pro, QT 7.6.6 [view my complete system specs]
  • Fri, May 11 2018 2:09 PM In reply to
    • mecom
    • Posts 4
    • Points 50
    ah great, thank you very much. That solves the problem for the moment. Yes
    Is known, if some kind of 'QT reference similar funcationality' can be implemented by Avid beside/without Quicktime?
    Because to be able to export references was one of the most valued advantages for us over other NLEs.
  • Fri, Jan 18 2019 3:37 AM In reply to
    • Doug Abel
    • Posts 35
    • Points 415
    Ya bummer about Media Encoder not supprting that any more. Will try the older version.
    But what do people in general find is the fastest way to make a file of appropriate sixe to get up to Vimeo, doesn't have to be super-high quality, just something to screen on a laptop. In the past a quicktime ref and then use external software to crunch to H264 was the fastest, but now that I'm working remotely without an AE to help, I'm wondering if there's a better way.
  • Fri, Jan 18 2019 6:48 AM In reply to
    Op1A MXF, then use an encoder like AME.
    See Michael Phillips’ speed test comparisons halfway through this blog: http://24p.com/wordpress/?p=278
