Avid is pleased to announce the latest release of Media Composer v2018.5 on May 10th, 2018. The software is available through My Avid, Avid Application Manager, or the Download Center (login and password required). You must have a current Support & Upgrade plan to run the latest software.+ OS SUPPORT:This release now supports macOS 10.13.4 (High Sierra) as well as 10.12.6 (Sierra), 10.11.6 (El Capitan), and 10.10.5 (Yosemite).
+ NEW FEATURES:- Get Info Window Update- Hybrid Log Gamma Transformation- Change tract in create/edit Marker Dialog
+ DONGLE USERS:Please note that the sentinel drivers for dongles is no longer automatically installed. After you install MC, you must install the sentinel drivers from the /Applications/Utilities/Avid Utilities/Sentinel Driver folder.
+ NITRIS DX/MOJO DX USERS:Please note the DX driver is NOT automatically selected in the install process. Within the MC installer, when you get to Installation Type, be sure to select the Avid DX Driver under Media Composer Editing Application.
+ BUG FIXES:This release addresses 75+ bugs since the last release, including:
- In some instances, after rendering a Compressor/Limiter effect, some of the audio no longer plays.- In some instances, the Reduce/Enlarge buttons did not work properly in the Effect Editor.- The editing application exited from Full Screen Play when you saved changes. - With the release of Mac OS v10.13.x (High Sierra), Media Composer could not write (i.e. capture, import, render) to the system drive.+ FOR MORE INFORMATION:See the ReadMe or What's New documents published on the Knowledge Base prior to upgrading if you have any questions.If you have general issues with installing or running the release, post them here. If you think you have found additional bugs, please start a new thread.
Thank you Kevin.
Desktop PC
3 Heads Digital Films
Kevin Klimek: + DONGLE USERS:Please note that the sentinel drivers for dongles is no longer automatically installed. After you install MC, you must install the sentinel drivers from the /Applications/Utilities/Avid Utilities/Sentinel Driver folder.
I'm a dongle user.
I don't have a Sentinel Driver folder in my Avid Utilities folder, but instead I have an AvidDXDriver .zip file, is that the same thing?
Also, as I am about to download v2018.5 from Media Composer Standard Support, I also see available to download a Dongle Updater file, should I also install that?
Sixteen hours later and I still don't have Avid 2018.5 in My Avid/My Products.
I haven't tried downloading Avid 2018.4 and seeing if 2018.5 is in the App Man, I'm on a tight bandwidth and would perfer to only download it once.
EDIT | I finally got 2018.5 in the Download Centre but it took a few goes, still nowhere to be found in My Avid.
After installing 2018.5 for Dongle based installation here on Mac OS 10.10.5 this was the correct path for me and in that folder was the required SentinelSystemDriver.pkg file. At this time the AvidDXDriver .zip file for me is in the Applications/Utilities/Avid Utilities folder.
Andrew:Also, as I am about to download v2018.5 from Media Composer Standard Support, I also see available to download a Dongle Updater file, should I also install that?
Marty McLean: I finally got 2018.5 in the Download Centre but it took a few goes, still nowhere to be found in My Avid.
Ι have uninstall 2018.4 and install 2018.5 no problems.
No need to install a driver.
Dongle too.
Marty
Let me check your My Avid. Can you PM me your email address so I can check it?
Twitter: avidmarianna
www.avidcustomerassociation.com | Connect 2019 | April 6-7 | Aria, Las Vegas, NV
AndrewAction: Andrew:Also, as I am about to download v2018.5 from Media Composer Standard Support, I also see available to download a Dongle Updater file, should I also install that?If you have not run a dongle update in your current 12 support package I would suggest you do a dongle update before installing 2018.5.
It's asking for my dongle serial number. I entered it and it won't accept it. I rechecked the number to make sure it's correct. My dongle is ten years old though. I initially got it when I was a film student. Of course, I'm not a film student anymore and I don't think the MC version that I have now is a student version and I'm using a different computer now, but I could be wrong.
Andrew:It's asking for my dongle serial number. I entered it and it won't accept it.
Andrew:My dongle is ten years old though.
AndrewAction: Andrew:It's asking for my dongle serial number. I entered it and it won't accept it.Which version of MC are you upgrading from? If earlier than 2018.4 then that maybe why you do not see the Sentinel driver where you would expect it from the 2018.5 Readme notes in Kevin's post. Yes it's earlier, it's 2018.2. Andrew:My dongle is ten years old though.My dongles are that age or older so I do not THINK that is an issue. Can you try with the dongle plugged directly into a USB 2 port on your iMac?
I have it on a USB port in my keyboard. Would plugging it directly in my iMac make a difference? I've been able to open MC with the dongle plugged my keyboard.
Andrew:Would plugging it directly in my iMac make a difference?
Andrew:Yes it's earlier, it's 2018.2.
If not I am out of ideas so I suggest you gather your dongle System ID & Avid account details and email them to Raff raff.condalorATavid.com or Marianna marianna.montagueATavid.com It is their weekend so response times may be a little slower than usual.
AndrewAction: Andrew:Would plugging it directly in my iMac make a difference?Probably clutching at straws but it is possible. Andrew:Yes it's earlier, it's 2018.2. If you still have the 2018.2 installer download I would uninstall 2018.2. Install but not open 2018.5. Go to the /Applications/Utilities/Avid Utilities/Sentinel Driver folder. and install the Sentinel driver. Open the Avid Application manager and see if there is a dongle update. If so use it and then try 2018.5. If not I am out of ideas so I suggest you gather your dongle System ID & Avid account details and email them to Raff raff.condalorATavid.com or Marianna marianna.montagueATavid.com It is their weekend so response times may be a little slower than usual.
Thanks, have to step out, I'll try your suggestions tomorrow morning (Sunday).
Marianna: Marty Let me check your My Avid. Can you PM me your email address so I can check it? Marianna
PM'd, cheers Marianna!
AndrewAction: Andrew:Yes it's earlier, it's 2018.2. If you still have the 2018.2 installer download I would uninstall 2018.2. Install but not open 2018.5. Go to the /Applications/Utilities/Avid Utilities/Sentinel Driver folder. and install the Sentinel driver. Open the Avid Application manager and see if there is a dongle update. If so use it and then try 2018.5.
OK, I installed 2018.5 and installed the Sentinel driver and found the dongle update in the Application Manager. It gave me the Dongle Update Instructions, but this is where I'm stuck. It told me to go to the Application Manager in my dock since I have a Mac, but I don't have an Application Manager in my dock. I have it in my Avid folder in my Application Manager folder. I click on it and I can open Licensing. It tells me to go to the Choose action menu, but I don't see where the Choose action menu is. This is where I am stuck.
