Latest post Sat, May 12 2018 3:38 PM by smrpix. 2 replies.
  • Thu, May 10 2018 8:47 AM
    Avid XML?
    I've worked with Final Cut Pros .fcpxml format for extracting various info about a project and need to do the same for productions made in Avid. However I've got a bunch of .avb-files which seems like another format. We've with somewhat of a success extracted data from and ALE, but aint there a textbased equivalent of the fcpxml-format for Avid? The goal is to calculate the duration of all audio and getting the filepaths.
  • Sat, May 12 2018 5:28 AM In reply to
    • Marty McLean
    • Joined on Tue, Aug 16 2016
    • Sydney, NSW, Australia
    • Posts 43
    • Points 455
    Re: Avid XML?
    AVB files are Avid Bins, containing media and sequences; AVP are Avid Projects, containing project settings.
    Export the sequences as an AAF, that is the closest equivilant to an XML or FCPXML that Avid supports natively.
    2014 MacBook Pro with macOS 10.14.3 | Avid 2018.12.2 with PhraseFind + ScriptSync | 2.5GHz i7 | 16GB | 2GB GT 750M [view my complete system specs]
  • Sat, May 12 2018 3:38 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,364
    • Points 16,815
    Re: Avid XML?
    Resolve and Premiere can read/write both aaf and xml.  You can try to use either of those as a "translator."
