Latest post Tue, May 8 2018 9:11 PM by Kevin Klimek. 3 replies.
  • Tue, May 8 2018 3:29 PM
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,309
    • Points 40,050
    Panasonic P2 DV and AMA
     Doing a pro bono project which will be shot on older Panasonic P2 cameras as DVCPro DV.
    Doing testing now.
    The old, non-AMA import works in MC 8.5.3.  But the AMA route is all messed up.  Using proper AMA plugin (4.7.1) according to Panasonic website.  Many prolbems.
    Is this just a case of SD being slowly phased out?
    And as an a note, Premiere Pro 2017 did not handle it well either.....
    Jef Huey
  • Tue, May 8 2018 8:15 PM In reply to
    Re: Panasonic P2 DV and AMA
    What do you mean by "All messed up"? What error do you get?
  • Tue, May 8 2018 8:37 PM In reply to
    • jef
    • Maryland
    • Posts 3,309
    • Points 40,050
    Well, forget what I wrote.
    I went back to get repo steps and realized my issue was that I was trying to link directly to a P2 card reader.  In that situation I was always "down" 1 level to many in the file structure.
    I copied the entire contents of the P2 card into a new folder "Card1" on a hard drive .  I then linked to that folder and all worked as it should.
    A case of not having done this particualar camera workflow in about 2 years .....
    So - never mind.  But thanks for responding and getting me to push forward.
    Jef
    Jef Huey
  • Tue, May 8 2018 9:11 PM In reply to
    No problem. Glad to hear you figured it out!
