Latest post Thu, May 10 2018 4:19 PM by smrpix. 2 replies.
  • Mon, May 7 2018 2:04 PM
    • Pepijn1987
    • Joined on Mon, May 7 2018
    • Posts 1
    • Points 25
    Title effect on source material
    Hi there,
    I have been working on a vlog in AVID using material shot with my Samsung Galaxy S8. I am working on the latest version of AVID in a project with settings 1080P/25fps. On some, not all, of my imported media files there appear to be title effects, unrendered. I have trouble with playing timelines and researched the message I keep getting, which could be related to effects wrongfully or not rendered (see message below)
    "Exception: DIDReader::XraiseUnexpectedStreamStatus async timeout error".
    Can anybody help with my problem? Can I either remove effects from my imported media and if I can, how does this work? Or can I render the effect on my imported media and if so, how does this work?
    Hope my question is a bit clear.
    Kind regars,
    Ppeijn
  • Thu, May 10 2018 4:16 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 1,662
    • Points 18,270
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: Title effect on source material
    Hi Ppeijn,
       Please complete your Profile to include machine specs and OS version. This will help us resolve the issue.
    RalphC
  • Thu, May 10 2018 4:19 PM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,336
    • Points 16,425
    Far more likely it's a timing (frame rate) modifier.  GS8 shoots variable frame rate (VFR) natively.
    Transcode to a native Avid codec for easier editing.  You can choose to keep the VFR or change to a Constant Frame Rate, but you must output at CFR.
