Latest post Fri, May 4 2018 5:03 PM by jef. 6 replies.
Page 1 of 1 (7 items)
  • Thu, May 3 2018 10:03 AM
    • derDoyle
    • Joined on Tue, Aug 18 2015
    • Berlin, Germany
    • Posts 81
    • Points 935
    MC2018.4 Enlarge in Effect Editor does not update immediately
    Hello,
    if I hit Enlarge in the effect editor, for example with a 3D Warp, the monitor does not update. Only when I step back/forward one frame it updates. Reduce seems to work fine.
    Can anybody confirm?
    Doyle
    Clients: MacPro6.1 (2013 "Trashcan"), 3,5GHz 6-Core, 16GB (1866) RAM, AMD FirePro D500, 256GB SSD, macOS 10.12.2, Avid MediaComposer 8.7.2, NitrisDX... [view my complete system specs]
    Passionate In-House Avid Support
    Admin of the German Avid Community on Facebook
  • Fri, May 4 2018 2:56 PM In reply to
    Re: MC2018.4 Enlarge in Effect Editor does not update immediately
    Not seeing that here. For clarification, are you using the buttons in the effect editor, buttons mapped elsewhere or keyboard shortucts?
  • Fri, May 4 2018 3:03 PM In reply to
    • derDoyle
    • Berlin, Germany
    • Posts 81
    • Points 935
    Hello,
    I am using the buttons under the record-monitor. Doyle
  • Fri, May 4 2018 3:17 PM In reply to
    OK. Again, not seeing that here. Have you tried a different Avid user to see if the problem persists?
  • Fri, May 4 2018 3:32 PM In reply to
    • derDoyle
    • Berlin, Germany
    • Posts 81
    • Points 935
    Yes, testet with different/new user on two machines.
    Both running macOS 10.13.3 and MC2018.4. One is an iMacPro and the other a MacPro5.1 with NitrisDX.
    Tested with different effects, 3D Warp, Animatte, MatteKey. One click on Enlarge, nothing happens, one frame back or forth an the Enlarge takes effect. So basically no realtime Enlarging.
    Tested in 1080- and UHD-projects.
    Even cmd+L doesn't work as long as the effect editor is open.
    Doyle
  • Fri, May 4 2018 3:41 PM In reply to
    Maybe it has something to do with High Sierra then? I'm on El Cap and can't replicate it.
    Maybe someone else on High Sierra can check and confirm?
  • Fri, May 4 2018 5:03 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,309
    • Points 40,050
    Are you seeing this in MC user interface or on a broadcast monitor connected via an IO?
    Jef
    Jef Huey
