Latest post Mon, May 7 2018 8:09 PM by Marianna. 3 replies.
  • Sat, Apr 28 2018 7:16 PM
    • danpersons
    • Joined on Sun, Sep 2 2007
    • Posts 6
    • Points 90
    Priority Exception
    Trying to run Composer First on a Mac Mini, updated to High Sierra, 8 gb memory. When I try to bring up the program, keep getting this message: "Exception: std:: exception, what: Failed to change priority."
    Not able to get into program because of this. Can anyone advise? Thanks!
    Dan
    Filed under: ,
  • Fri, May 4 2018 6:10 PM In reply to
    • Rüdiger
    • Joined on Fri, May 4 2018
    • Kiel, Germany
    • Posts 1
    • Points 15
    Re: Priority Exception
    Hello,
    same here on a 2009 Mac Pro 3,1. I started the application from a shell window to see more output:
    Mac-Pro:MacOS rmuetze$ ./AvidMediaComposer
    Reset the maximum number of open files to 10240
    [   0.000][WARNING]: libpng warning: iCCP: known incorrect sRGB profile
    [   0.001][WARNING]: libpng warning: iCCP: known incorrect sRGB profile
    [   0.002][WARNING]: libpng warning: iCCP: known incorrect sRGB profile
    [   0.003][WARNING]: libpng warning: iCCP: known incorrect sRGB profile
    [   1.274][WARNING]: QObject::startTimer: Timers cannot have negative intervals
    ELFCreateMutex - 182c0: No such file or directory
    ELFCreateMutex - 555b7a2c: File exists
    ELFCreateMutex - be6ece71: Resource temporarily unavailable
    <-> LavaFlow already inited
    02:12:05.865978    Exception: std::exception, what:Failed to change priority. 18.4.0.48530.0
    [  14.134][WARNING]: libpng warning: iCCP: known incorrect sRGB profile
    [  14.135][WARNING]: libpng warning: iCCP: known incorrect sRGB profile
    [  14.154][WARNING]: libpng warning: iCCP: known incorrect sRGB profile
    [  14.163][WARNING]: libpng warning: iCCP: known incorrect sRGB profile
    [  47.921][WARNING]: libpng warning: iCCP: known incorrect sRGB profile
    Tried with a clean user profile to no avail. I also tried a complete uninstall and re-install with latest updates. OS version is 10.13.4, 12 GB of RAM, SSD boot drive for the OS and a software RAID for data. Any help much appreciated.
    Best regards
    Rüdiger
    Early 2008 MAC Pro 3,1 2 x 2,8 GHz Quad-Core Intel Xeon 12 GB 800 MHz DDR2 FB-DIMM ATI Radeon HD 2600 XT 256 MB Dual Apple Cinema Display 23 inch [view my complete system specs]
  • Sat, May 5 2018 7:31 AM In reply to
    • Nihil
    • Posts 11
    • Points 175
    I'm having the same issue; MC 2018.4 and macOS 10.13.4
    Mac Pro 3,1 8-core 3Ghz - 12gigs RAM - Radeon 7950 Mac Edition - Avid Media Composer 2018 [view my complete system specs]
  • Mon, May 7 2018 8:09 PM In reply to
    • Posts 9,789
    • Points 212,705
    First Mac OS X 10.13.4 was not approved by avid.  We have seen some issues with the OS and how it relates to several things such as security etc. that have us doing more testing so that could be the issue.
    Did all of you check the computer spcifications for MC | First ?
    Basics....
    Long winded info. http://resources.avid.com/supportfiles/attach/Mac_Current_CPU_Specifications.pdf So for example....  Mac mini 2.6/2.8GHz dual core Intel i5 or 3.0 Ghz dual core i7 Late 2014 is not supported....  its an i5 first of all and not beefy enough to handle the tasks it needs too. Check it out first before you forge ahead Marianna
    AOL IM:  avidmarianna
    Skype: mariannamontague
