Latest post Wed, Apr 18 2018 11:17 PM by TVJohn. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Apr 18 2018 10:12 AM
    • TrevorA
    • Posts 1,148
    • Points 13,005
    Win10 Pro or Creators?
    Going to update a z400 that is happily running Avid but falls over a bit with Premiere (may be other reasons, but I figure I should drag it out of win7).
    Are folks happily using Win10 Creators version? Not entirely sure what the difference is.
  • Wed, Apr 18 2018 11:04 AM In reply to
    Re: Win10 Pro or Creators?
    I'd stick with Pro (although I have a system running Creators fine)
    I think you get eralier updates of new features and that may cause issues.
    Stick to the supported OS
  • Wed, Apr 18 2018 11:57 AM In reply to
    • ck123
    • Joined on Wed, Jul 17 2013
    • PA
    • Posts 139
    • Points 1,750
    Home, Pro, and Enterprise are Editions.
    Anniversary, Creators, Fall Creators, and (soon) Spring Creators are Versions.
    All Versions are available for all Editions. You can have Windows 10 Pro Fall Creators Update.
    Comparing to the new Avid edition/versioning. This would be similar to how MC First, MC, and MC Ultimate are Editions. Then 2018.1, .2, .3 are Versions. Each version is available for all editions, hence we have MC First 2018.4 and MC Ultimate 2018.4.
    All super confusing. But, you would need to check the read me for the specific Avid Version you are installing to see which Windows version(s) it is compatible with. But, regardless of Version you need to stick with the Pro edition.
    HP zBook 17 G3, z220, HP z240, HP z420, HP z440, HP z840, HP Z4 G4, Dell Precision 3430, Dell Precision 7810, Apple iMac i5 27-Inch (5K, Late 2015). 16GB... [view my complete system specs]
  • Wed, Apr 18 2018 12:26 PM In reply to
    ck123 is right with the edition/versioning names (although the next update for Windows 10 will be called Windows 10 April 2018 Update, not Spring Creators Update). I run the Fall Creators Update and have zero problems with it.
    MC will run on the Home edition of Windows 10, but it's not supported by Avid, so customer service won't be happy if you're using that edition. So yes, go for Pro.
    CPU: AMD Ryzen Threadripper 1950X 16-core 3.4GHz GPU: GeForce® GTX 1080 Ti 11G MB: Gigabyte X399 Designare EX RAM: 64GB Kingston HyperX Predator HX430C15PB3K4... [view my complete system specs]
  • Wed, Apr 18 2018 7:17 PM In reply to
    • LDV20
    • Joined on Fri, Nov 18 2011
    • Posts 171
    • Points 2,045
    I have windows 10 most recent creators update as well.  No problems at all.  I did try not to allow windows to upgrade -for awhile it worked but then it changed my settings and informed me of an upgrade - anwyay no problems with recent upgrades here on MC
    Symphony 2018.3 - Win 10 pro, Asus PrimeZ270 with i7 7700 cpu, Quadro P2000,64gig memory, 500gig SSD system drive, WD 5TB,and 2TB media, BM Intensity... [view my complete system specs]
  • Wed, Apr 18 2018 11:17 PM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 4,327
    • Points 53,490
    With increased security risks, any computer running without enhanced security is running an increasing risk. While I might delay some MS updates, I would keep abreast as to the security reasons for each update.
    Using MC 8.4. Avid FX6.4, Vegas Pro 15/ DVD Architect 6pro, DVDit6.4proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Sony EX-1R, Canon XH-A1, GL2, GL1, Canon EOS 60D
