Hi there. I'm super new to the software and am just getting started setting up my working environment. One thing I need to do is use enable the alldrives command within the console.
However, after I open the console from the tools menu it doesn't accept any keyboard input. What am I missing? I can not type anything. I tried typing "help commands" just to see if I can get some feedback and nothing....
Thanks in advance for you feedback.
Frustrated...
Is the command entry box receiving focus (it's the blank box at the bottom of the console dialog)? You should see the flashing text caret at least. If not, try left-clicking in the entry box and see if it gets focus. If that doesn't work, try opening another dialog box (like the source broweser) and see if that's getting keyboard focus.
Dave S.
There doesn't appear to be an entry box at all. Here is a screen snip of the console dialog.
The focus can be changed from the console to other dialog boxes within AMC and to other applications. Keyboard input is working fine in all other situations.
Is there a setting somewhere that disables or removes the input box from the console?
There should be an entry box, along with a couple of buttons you're also missing. I'm wondering if your user profile is corrupt (assuming MCF has user profiles).
