Latest post Sat, Apr 14 2018 2:39 PM by JCBond. 4 replies.
  • Mon, Apr 9 2018 2:16 PM
    • Dave
    • Joined on Tue, Aug 14 2012
    • United Kingdom
    • Posts 22
    • Points 250
    Do we still need quicktime 7 install with MC 2018.4?
    Is it still a requirement to install quicktime to use Animation movs?
    If I don't have QT installed then I get a warning when opening MC that recommends I install quicktime, suggesting I definitely need it.
    On the AMA Plug-ins page it says:
    "QuickTime plug-in
    Directly access QuickTime movie files, including ProRes and many other codecs, without transcoding or re-wrapping files. This plug-in comes installed with Media Composer. "
    On the README_Avid_Editor_v18.4.pdf it states that "Quicktime is not supported on Windows 10", does that mean the QT plugin installed with avid?
    It would be good to clear up exactly what quicktime formats are supported by Media Composer without the need for QT 7 to be installed.
    Media Composer 2018.12, Windows 10 Pro, Dell T7910, Intel Xeon E5-2687W v4 @3.00GHz 12-Core, 96GB RAM, EVGA Nvidia GTX 1080 ti SC2, Dell P2415Q, Akitio... [view my complete system specs]
  • Mon, Apr 9 2018 4:08 PM In reply to
    • JCBond
    • Joined on Sat, Mar 11 2006
    • Van Nuys CA, USA
    • Posts 109
    • Points 1,145
    Re: Do we still need quicktime 7 install with MC 2018.4?
    You should still download and install Quicktime 7 using custom options, and ONLY installing the QUICKTIME essencials option.
    https://support.apple.com/kb/DL837?viewlocale=en_US&locale=en_US
    System 1: Symphony Nitris DX - HP xw8600 8xCores - Windows 7 SP1 64 bit. System 2: Symphony Nitris DX - HP xw8600 8xCores - Windows 7 SP1 64 bit. System... [view my complete system specs]
  • Wed, Apr 11 2018 3:47 PM In reply to
    • Dave
    • United Kingdom
    • Posts 22
    • Points 250
    Thanks, still the same then.
    Guess I need to look into a better alternative to the Animation codec for alpha support!
  • Sat, Apr 14 2018 2:29 PM In reply to
    • aVienna
    • Joined on Fri, Jul 21 2006
    • Vienna
    • Posts 64
    • Points 730
    For ProRes at least I have just successfully setup a new workstation with Windows 10 Pro and MC2018.4 WITHOUT QuickTime.
    Linking of ProRes files works.
    1) MC Symphony 2018.11, HP Z420: Intel Xeon E5-1650 v2, 6 cores @3.50GHz, 40GB RAM, Windows 10 Pro, Z TurboDrive 256GB as system disc, Thunderbolt 2 PCIe... [view my complete system specs]
  • Sat, Apr 14 2018 2:39 PM In reply to
    • JCBond
    • Van Nuys CA, USA
    • Posts 109
    • Points 1,145
    Any linking with the avid generic plug in will work, but the avid plug in does not recognize all flavors of QuickTime files YET...
    also many import file types will not work w/o QuickTime installed.
