Latest post Sat, Mar 31 2018 11:12 PM by George Angeludis. 2 replies.
  • Sat, Mar 31 2018 12:20 PM
    Effect on filler does not work - procedure change?
    Hi!
    Does anything have changed in applying a effect to a filler. (Deinterlacing on top most track.)Effect on Videotrack works. (Workaround is Videomixdown and applying the deinterlace FX on that)
    Anny ideas?
    Greetings, Mike
    Filed under: ,
  • Sat, Mar 31 2018 3:05 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 560
    • Points 7,130
    Re: Effect on filler does not work - procedure change?
    Not all effects can be applied to filler.
    Why do you want to do this anyway? Are you applying the de-interlace effect to more than one clip?
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Sat, Mar 31 2018 11:12 PM In reply to
    Yes it doesn't work correctly in 2018.3.
    Some times it works and sometimes after a restart of MC.
    If you are on CC at green 10bit output for example and want to apply an effect to a filler some times it doesn't work untill
    you close and open MC again.
    Desktop PC
    3 Heads Digital Films
