Latest post Sat, Mar 24 2018 3:14 PM by DStone. 11 replies.
Page 1 of 1 (12 items)
  • Thu, Mar 22 2018 10:05 AM
    • mkj
    • Sweden
    • Posts 404
    • Points 5,310
    Xeon vs i7?
    Hi
    What is best for Avid MC?
    Xeon or i7?
    looking at HP z2, and want to know if I should choose the one with i7 or Xeon, both with 4 cores, 3,7 Ghz.
  • Thu, Mar 22 2018 2:29 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,569
    • Points 45,830
    Re: Xeon vs i7?
    Taking a quick look at that system, I notice that it has the Xeon E3-1205 and  E3-1225 as options. Neither of these have HyperThreading. The only Xeon on the list with HT is the E3-1245 (which I presume is the one you're looking at). The price is going to be comparable between that and the I7-7700, but you can overclock an I7 and you can't overclock the Xeon. Overclocking may be desirable (once the warranty runs out).
    Otherwise, there's no real difference between the two configurations. The performance is going to be the same (similar clock speed, same # of cores, cache memory, etc.) The I7 turbo boost is a little higher, but the base clock speed is a little slower so it evens out in the end.
    If it were me, I'd go for the I7 so I could overclock it down the line.
    Dave S.
  • Thu, Mar 22 2018 10:08 PM In reply to
    • mkj
    • Sweden
    • Posts 404
    • Points 5,310
    Re: Xeon vs i7?
  • Fri, Mar 23 2018 8:28 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,557
    • Points 65,175
    Re: Xeon vs i7?
    Xeon E is ageing, being the Xeon W out. The real question is Xeon W vs i9, but both CPUs are not an option on current HP workstations, nor with entry level Dell workstations.
    peace luca
  • Fri, Mar 23 2018 1:27 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,569
    • Points 45,830
    Re: Xeon vs i7?
    Consider the lowest cost i9-7900x is almost $1K and the high-end I9-7980XE is amost $2K, that's a lot of money for more threads but not a significantly faster clock speed over the I7. And the problem here is that when it comes to multi-core processing, the I9 is significantly faster. But MC tends to prefer faster clock over more cores. Anything else that likes to run a lot of threads will run much faster on the I9. I suspect that transcoding might be faster on the I9, but I'd be worried that editing is not significantly improved.
    And the Xeon W only has 1 sub $1K processor and that's not any better than the high-end I7. After that it's $3.5K for the next model up, and over $7K for the high end.
    Dave S.
  • Fri, Mar 23 2018 3:55 PM In reply to
    Re: Xeon vs i7?
    For single CPU configuration I prefer i7/i9. You can get more cores for cheaper. Also, you have access to QuickSync which can be beneficial to some encoding workflow.
  • Fri, Mar 23 2018 5:22 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 479
    • Points 5,725
    Re: Xeon vs i7?
    i gravitate towards xeon.
    protected ecc ram, a good idea if you sit atop terrabytes of data.
    i'm gonna pick up a Xeon W-2155 as soon as available.
    10 cores,  4.3Ghz turbo, what's not to like?
    During m research i fell in love with a motherboard:
    supermicro, X11DPX-T, hell yeah
    4 Gpus and then some. mewant.
    MC 2018.12.2 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX... [view my complete system specs]
  • Fri, Mar 23 2018 6:52 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,569
    • Points 45,830
    Re: Xeon vs i7?
    Just remember that ECC buffered memory is slower than non-bufferred. And ask yourself when the last time you had a memory error that didn't get caught.
    For me, Xeons are what you use for serious data modeling and analytics, as well as other app's that can really take advantage of all of the cores. This is one of my biggest issues with Media Composer. It needs an overhaul to run more things in parallel on the threads, and push more stuff through the GPU (and support multiple GPUs at the same time).
    Now, if I'm running Resolve, then the above mentioned MOBO with 4 GTX 1080 Ti's, (2) Xeon W-2195s and 2Tb of memory sounds just about right. Geeked Too bad it doesn't have Thunderbolt or USB 3.1 though.
    Dave S.
  • Fri, Mar 23 2018 8:06 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,557
    • Points 65,175
    Re: Xeon vs i7?
    I'm leaning toward Xeon, if money is no object, or i9 for budget sistems! HP doesn't offer latest generation Xeon processors at the moment, a beefed up Dell is around 15k, and a comparable iMac Pro costs roughly the same. Thunderbolt and USB 3.1 gen 2 are unavoidable nowadays. Since the OP is shopping for a Z2 I think that a Xeon W is not within budget. I'm a DIY kind of guy, but if You want to buy 24/365 support and an Avid certified system this is not an option. ciao
    peace luca
  • Sat, Mar 24 2018 12:48 PM In reply to
    • Bruno M
    • Joined on Thu, Feb 11 2010
    • London, UK
    • Posts 566
    • Points 7,250
    Re: Xeon vs i7?
    DStone:
    In my 25 years of using HP Zeon workstations I've never had one. But then, how would I know if EEC memory had ever caught an error and (say) saved me a corrupt export? Does the OS report it in an error message?
    Seems like a lot to pay in price and performance for an event which might be rarer than a full eclipse of the sun!
    HP Z800, HP G3 Studio, SonnetFusion RAID, Mojo DX, Symphony 2018.9, JVC DTV1910 HD tube monitor, HP Dreamcolor, Avid Artist Color [view my complete system specs]
  • Sat, Mar 24 2018 12:55 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 479
    • Points 5,725
    Re: Xeon vs i7?
    it's not only exports, also blocks in a raid array that become unrecoverable.
    anything that fights bit rot is good if your timescale is large.
    it's not only cosmic radiation causing memory errors.
    performance shouldn't be a concern with 4 channel ram.
    we're not insisting on ecc but leaning or gravitating.
  • Sat, Mar 24 2018 3:14 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,569
    • Points 45,830
    Re: Xeon vs i7?
    Bruno M:
    Windows (current versions) will only report if the ECC error could not be corrected. It will not report a soft error that was corrected.
    In 16Gb of memory, chances of ever seeing a soft error is very unlikely. Hard errors even in non-ECC memory get caught (usually by the system flaking out, assuming it will even boot). With high-end servers and 2Tb of memory (and yes, you can have such a system) ECC makes a lot of sense. The same goes for mission critical applications (you don't want your nuclear reactor doing something funky from a radiation induced memory error).
    Dave S.
