Latest post Mon, Mar 12 2018 1:01 AM by marluc. 18 replies.
Page 2 of 2 (19 items) < Previous 1 2
  • Sun, Mar 11 2018 4:22 PM In reply to
    Re: Can't capture HDV tapes
    Are you able to try another computer, just to troubleshoot where the problm lies?
    Win 7 Pro; HP 820z, 16GB ram; Composer Nitris DX, Squeeze v8.5 Pro _____ Also:___ Windows 7 Pro x64 Dell T3400 workstation E8400 3.0 Ghz 4GB Ram,... [view my complete system specs]
  • Sun, Mar 11 2018 6:40 PM In reply to
    • marluc
    • New York State
    • Posts 373
    • Points 4,590
    Don't have Avid on my other computers. What possible computer issue do you think it could be, and what would you suggest to troubleshoot it?
    marluc
    DESKTOP: 27" iMac/3.5GHz Quad Core i7/ 32 GB 1600 MHz DDR3, 8GB/1TBFlash Storage/NVIDIA GTX 780M 4GB, running OS X 10.9.2 and MC7.06. 1x 10TB Glyph... [view my complete system specs]
  • Sun, Mar 11 2018 7:56 PM In reply to
    It’s just a way of looking at the problem, fishing for a fix.
    If you did have access to another computer— perhaps you could install the original version of MC, and if sucessful just move the batched MXF files into your current system... and off to the races.
    if you do jnstall on an old PC, capture may work. Otherwise, call Avid and use your annual support plan.
    Good luck!
  • Mon, Mar 12 2018 1:01 AM In reply to
    • marluc
    • New York State
    • Posts 373
    • Points 4,590
    Miracolo!  Today I took a new approach to the problem: reviewed alll my deck settings and computer settings, moved the Firewire 400 cable to a different drive for input.  And, it worked! Most of the time.  Out of 20 I may have been able to capture 8 in Batch Capture.  Going back over my selections individually I did manage to get most of what I needed.  Moved to a different tape, which worked even better--captured all my selections. So whatever was the problem, my expeerience tells me that persistence is the best solution.  Thanks to all of you for your help!
    marluc
