Latest post Sat, Mar 10 2018 10:35 PM by George Angeludis. 3 replies.
  • Fri, Mar 9 2018 3:56 PM
    • BenoitM
    • Brussels, Belgium
    • Posts 1,131
    • Points 13,650
    Multicam and disk I/O perf: improvement suggestion
    Monitoring my computer disk performance while doing a multicam edit, I noticed that the clip currently being selected causes double I/O (for the same stream) on the drive where it resides; indeed, the selected camera causes the corresponding clip to be displayed both in the quad/nine split source monitor and in the record monitor, but I see no reason why this would require the same stream to be read twice ? Hint/question to engineering: isn't there some room for improvement in I/O, by reading the selected cam angle stream only once (and displaying it both in the quad/nine split source monitor and in the record monitor) ?
    MC 2018.5 (Symphony option)/BCC 10.0.5/RED 5.6; Matrox MXO2 Mini (8.0.0); DELL Precision M4700 - Intel Core i7-3740QM 2.7 GHz - 24 GB RAM; nVidia Quadro... [view my complete system specs]
  • Fri, Mar 9 2018 5:51 PM In reply to
    Re: Multicam and disk I/O perf: improvement suggestion
    SSD for editing and the most RAM you can have.
    I hope you are not using the MXO for this task.
    Desktop
    Corsair RM750X/Asus P8Z68 Deluxe(Gen3)/i7 2600K@4.4/Corsair 32G DDR3/PNY Quadro P2000D(390.77)/Samsung 850 Pro SSD(OS) 256 GB/ 2x2TB WD RE4@RAID 0/LG BH16NS40/W10 Pro 64bit/Media Composer Software 2018.7 with Symphony Option/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    3 Heads Digital Films
  • Fri, Mar 9 2018 10:17 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,131
    • Points 13,650
    George Angeludis:
    Yes of course; I'm not complaining, MCam is doing fine on my system (even with MXO2 active !), it's just that I wonder why the double I/O Wink : whatever the I/O and disk subsystem, if you double the I/O for a stream, you reduce the number of clips that can be streamed in parallel from a given disk, right ?
  • Sat, Mar 10 2018 10:35 PM In reply to
    BenoitM:
    Got it Benoit.
    Yes
    Desktop
