Latest post Fri, Mar 9 2018 12:41 AM by touviere7. 4 replies.
  • Wed, Mar 7 2018 5:12 PM
    • Rob
    • Joined on Thu, Nov 11 2010
    • NYC
    • Posts 83
    • Points 1,065
    Converting 29.97 to 25fps correctly
    Hey,
    I have a 60 minute film that was edited in a 29.97 sequence. I need to convert the film to 25fps to send it over seas.
    My first attempt was a failure. I opened a new 25fps project, imported the 29.97 film, transcoded it to 25fps and exported it same as source. I had lots of ghosting between cuts and movments.
    Is there another way of doing this correctly?
    Thank you
    MC 7 Nitris DX Z800, 12 GIGS, Windows 7, SP1 [view my complete system specs]
  • Wed, Mar 7 2018 5:26 PM In reply to
    Re: Converting 29.97 to 25fps correctly
    What you are seeing is blending arteafacts which is a common result of simple frame rate conversions.
    What you need is a motion compensated conversion. Avid can do it using fluid motion but the render times are massive.
    I'd send it out for an Alchemist conversion. You will get back a 25fps version with far fewer issues.
  • Wed, Mar 7 2018 7:36 PM In reply to
    Did you try an external encoder?
    TMPGenc Mastering Works or Media Encoder?
    Do you need H264?
    Desktop PC
    3 Heads Digital Films
  • Wed, Mar 7 2018 7:53 PM In reply to
    • Rob
    • NYC
    • Posts 83
    • Points 1,065
    I was going to run it through Media Encoder and see if that works.
  • Fri, Mar 9 2018 12:41 AM In reply to
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 591
    • Points 6,695
    we don't know too much details about your particular situation and need...
    but commenting on my very successful experiences with adobe media encoder for conversion,
    i would recommend exporting your timeline at the highest resolution possible (ama out to mxf op1a dnx hrhqx as example)
    and choose one of the mxf op1a setting  from adobe encoder.
    symphony 2018.12.1 - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (411.63) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2 - MSI... [view my complete system specs]
