Latest post Wed, Mar 7 2018 9:51 AM by BenoitM. 6 replies.
Page 1 of 1 (7 items)
  • Sun, Mar 4 2018 2:41 PM
    • BenoitM
    • Brussels, Belgium
    • Posts 1,135
    • Points 13,710
    Force QT plug-in for spanned AVCHD clips ?
    Continuing this MAC discussion (http://community.avid.com/forums/p/183780/854507.aspx#854507) :
    I am also currently facing spanned XA25 AVCHD clips transcode problems: no matter what I do, I get an error with the AVCHD MVP Plug-in during transcode; since I generally get better results with the legacy QT plug-in (i.e. slower perf but much less transcode failures or corruption when transcoding e.g. H.264 MP4), I wonder how I can force linking spanned AVCHD clips with the QT plug-in instead of the default AVCHD MVP Plug-in ? I know how to do it for individual clips, but haven't found a way to choose the plug-in when the 'PRIVATE' folder (containing the AVCHD spanned clips) is selected in the Source Browser.
    If AMA-linking of AVCHD spanned clips using QT is no longer an option, my next (cumbersome) workaround would be to concatenate the AVCHD clips using Canon's Data Import Utility then transcode to DNxHD with FFMBC then fast import, a workflow dating back from prehistorical times Sad....
    (NB: this system is a clean reinstall of OS and all apps just a couple of months ago...MC 8.9.4 then 2018.2)
    MC 2018.5 (Symphony option)/BCC 10.0.5/RED 5.6; Matrox MXO2 Mini (8.0.0); DELL Precision M4700 - Intel Core i7-3740QM 2.7 GHz - 24 GB RAM; nVidia Quadro... [view my complete system specs]
  • Sun, Mar 4 2018 5:14 PM In reply to
    Re: Force QT plug-in for spanned AVCHD clips ?
    Does your Canon program work well? Does it make a distinction between clips that should become stitched vs. others having non-continuous TC within the same Volune (Source chip)?
    As you know, when AVID MC’s AMA linking is available, it does make those distinctions, right?
  • Sun, Mar 4 2018 5:29 PM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,135
    • Points 13,710
    Telegram!:
    Yes it does; it even stitches together clips spanning cards (e.g. when relay recording was used -- the XA25 supports relay rec on 2 SD cards), and leaves alone isolated clips.
    Back to my original post, apparently QT is NOT an option when AMA-linking AVCHD (spanned or not)....
    I just have imported / joined the source clips using Canon's utility, creating a single long AVCHD file (.mts) which I have AMA-linked. I will now retry transcoding and see...crossing fingers
  • Sun, Mar 4 2018 5:59 PM In reply to
    Sounds great.
    Good luck!
  • Tue, Mar 6 2018 10:52 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,135
    • Points 13,710
    BenoitM:
    mmmhhh not good news [:'(]; I continue getting an error (Exception: AVCHD Reader:8000000c) a few minutes after initiating the transcode process (background or foreground) even with this new single large AVCHD (MTS) file with 2018.2 / Win7...the same file seems to transcode OK as I speak on my 'secondary' system (with 8.9.3 / Win10), albeit way much slower b/c of the system specs (MS Surface Pro). Time to  create a support case...
  • Wed, Mar 7 2018 12:35 AM In reply to
    Which camera/system is involved? Just curious.
  • Wed, Mar 7 2018 9:51 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,135
    • Points 13,710
    Canon XA25 - AVCHD 24 Mbps (PsF, 25 fps)
