Latest post Thu, Mar 8 2018 12:32 PM by 01Media. 21 replies.
Page 1 of 2 (22 items) 1 2 Next >
  • Fri, Mar 2 2018 5:07 PM
    • 01Media
    • Joined on Fri, Mar 2 2018
    • Posts 0
    • Points 0
    Symphony Option slows down workstation
    Hi
    We have a BIG problem with MC 8.7.2 dongle version with symphony option. Working long and complicated
    sequences where symphony color correction is used, the workstations BECOME VERY SLOW TO
    MANAGE EDITING COMMANDS. This problem does not exist if THE SAME workstation uses a
    dongle with THE SAME SOFTWARE VERSION WITHOUT SYMPHONY OPTION
    Have someone already had this problem? Is it a known problem?
    Motherboard Asus X99-M WS/SE, CPU Intel I7-5820K, 32 GB RAM DDR4, Nvidia Quadro P600, Win10 Pro, MC 8.7.2 [view my complete system specs]
  • Sun, Mar 4 2018 2:39 AM In reply to
    • DStone
    • Massachusetts
    • Posts 3,569
    • Points 45,830
    Re: Symphony Option slows down workstation
    Welcome to the forums. Before we can begin to help, we need some more information. First, we need your system specification (see mine below for an example). Second, is this something new (i.e. something which started with 8.7.2), or is it a long standing issue? Have you recently updated your OS or driver versions? Are you using something like ISIS? Are the media drives internal or external and how are they connected?
    Dave S.
  • Mon, Mar 5 2018 1:09 PM In reply to
    • 01Media
    • Posts 0
    • Points 0
    Hi Dave.
    What happens is really curious.
    I want to describe you our workflow. Editors use 8.7.2 MC without Symphony Option, they work on different sequences until each episode is ending. The results are 56 minutes timelines with a lot of edit and effects (also BCC effects). The colorist starts working on these sequences. He used 8.7.2 MC with Symphony Option. At the start his workstation are performing as usual. As soon as he use color correction tools, his workstation BECOME UNEXPECTEDLY SLOW.
    But if each other MC users without Symphony Option open the same timeline, with the same effects (color corrections included, that can read but not edit), the workstation performance appear unalterated: they are as fast as at the start.
    We have done several tests, and we have the same problem on workstations with different system specifications, both with media shared on network and on local drive.
    The problem occurs only on MC with Symphony Option. We have dongle versions, and checking this difference is quick and easy.
    It’s a new problem because we have recently updated several MC dongle versions with Symphony Option.
    Has anyone else encountered the same problem?
  • Mon, Mar 5 2018 1:39 PM In reply to
    I presume this is with Avid DNx media ( not AMA linked media)?
    Does the performance improve if you render the real time color corrections?
    How much RAM do you have on the system and what GFx card?
  • Mon, Mar 5 2018 2:13 PM In reply to
    • 01Media
    • Posts 0
    • Points 0
    No AMA linked. The footage ingest in XDCAM 50. If you render real time color nothing performance improve. Only commit the timeline the performance improve, but the workstation is still struggling. In media composer (no symphony option) it is not necessary the timeline commit.
    The system has 32 GB RAM and Quadro P600 video card.
  • Mon, Mar 5 2018 5:46 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,413
    • Points 41,200
    01Media:
    You mention timeline commit.  Are these multicam sequences?  If so, and if pic is locked, I would commit the sequence anyway for several reasons.  That is just my workflow and does not really answer your base question.
    To that question, are you on shared storage?  Not sure this would factor in, but maybe ....
    Jef
    Jef Huey
  • Mon, Mar 5 2018 11:57 PM In reply to
    • 01Media
    • Posts 0
    • Points 0
    Yes, they are multicam sequences but the pic is not loked. The storage is a shared storage but it is not understandable that media composer is fast and media composer with symphony option is slow.
  • Tue, Mar 6 2018 11:06 AM In reply to
    • dmfreeman
    • Michigan
    • Posts 1,851
    • Points 24,235
    Could the issue here possibly be the graphic card?  The P600 only has 2 gigs of memory, and I believe that the spec for MC calls for a 4 gb graphic card.
    Just a thought.
    Denny
    Media Composer 8.5.4, BCC 10.0.0074, AvidDVD 6.4.4, Boris Red 5.5.2.1382, Asus P9X79 Pro Motherboard with Intel 3930K Processor. 32 gigs DDR3 ram, Windows... [view my complete system specs]
  • Tue, Mar 6 2018 11:18 AM In reply to
    • 01Media
    • Posts 0
    • Points 0
    if so why sympony option has the problem and media composer no? however, I have the same problem on AMD Radeon Pro WX7100.
  • Tue, Mar 6 2018 12:20 PM In reply to
    Will try to reproduce tomorrow.
    In the meantime: is your colorist using secondaries? That might account for a difference in processing power (as MC may not play those back IIRC).
  • Tue, Mar 6 2018 2:48 PM In reply to
    Have you tried turning off the GPU in the render setting?
    That maybe worth a try.
  • Tue, Mar 6 2018 3:53 PM In reply to
    • 01Media
    • Posts 0
    • Points 0
    Job ter Burg:
    This is an excellent observation. I will try to do a basic color and see if the problem does not appear
    An idea that I have done is that the media composer is 64bit while symphony is still 32bit
    Yes Pat,  GPU turning off.
  • Wed, Mar 7 2018 6:20 AM In reply to
    • dor
    • Israel
    • Posts 596
    • Points 7,585
    I think MC 8.72  had issue with the GPU with color corectin, and "disable GPU" in the render setting, solved render and playback problems
    MC 2018.4 + MXO2 mini. CPU I7 2600K + 32GB RAM. Nvidia GTX970 driver 388.71. QT.7.7.9 [view my complete system specs]
  • Wed, Mar 7 2018 7:45 AM In reply to
    • 01Media
    • Posts 0
    • Points 0
    Dor the problem there is also in versions 8.10 and 2018.1 that I tried. I tried to disable the GPU.
    However when you load a complex timeline the interface tabs also respond slower. You really feel the workload feeling of the workstation
  • Wed, Mar 7 2018 4:40 PM In reply to
    • 01Media
    • Posts 0
    • Points 0
    Timeline of 24 minutes without color the problem persists
    Timeline of 24 minutes without color and without efx the problem persists
    Timeline of 12 minutes without color and without efx the problem is less serious
    Timeline of 6 minutes without color and without efx the workstation is fine
    Timeline of 6 minutes with color and with efx the workstation is fine
    Timeline of 12 minutes with color and with efx the problem is less serious
    Timeline of 24 minutes with color and with efx the problem persists
    The test is on consolidated locally on ssd.
