Latest post Thu, Nov 28 2019 7:32 PM by camx-media. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Mar 2 2018 1:38 AM
    MSM_CONS_MISMATCHED_WRITERS
    Lately I have been having problems rendering sequences. I've been getting this message (msm_cons_mismatched_writers) I have tried searching online for any tips but no luck. This error only happens when trying to render audio effects. For some reason Avid will render some but not others in the same sequence, and this will stall the export. What's wierd is that even though Avid stalls during the export the file does finish exporting on the background. File will play and everything looks good, so once I see this I am forced to forced quit Avid. I've tried rendering to a local drive same problem. I've moved the project to another drive same, tried removing the effects and adding new ones...SAME PROBLEM. I am wondering if anyone else has had this problem or atleast know about the error message. This is not a consistent issue it picks and chooses which projects to be picky with, which makes recreating the problem a little bit hard to trouble shoot.
    I am running on a HP z840 workstaion Windows 10, Avid MC 2018.2 and Application Manager 2018.2
    Share storeage (EVO)
    Avid Media Composer 8.3 W/Nitris DX, HP Workstation z820, Windows 7 64bit, 16gb Ram, Intel(R) Xeon(R) CPU E5-2640 0 @ 2.50GHz 2.50GHz (2 processors) [view my complete system specs]
  • Sat, Mar 3 2018 9:39 PM In reply to
    • Robert L
    • Joined on Wed, Sep 27 2017
    • Posts 1
    • Points 15
    Re: MSM_CONS_MISMATCHED_WRITERS
    Same exact problem. Running HP z440, Windows 10, MC 2018.2 and App Manager 2018.2
  • Sat, Jun 30 2018 5:25 PM In reply to
    • Babylon
    • Joined on Tue, Nov 30 2010
    • Sweden
    • Posts 52
    • Points 660
    Hi
    I have same problem... do you find any solution?
    MacBook Pro (15-inch, 2018) High Sierra 10.13.6 2,2 GHz Intel Core i7 16 GB 2400 MHz DDR4 Radeon Pro 555X 4096 MB Intel UHD Graphics 630 1536... [view my complete system specs]
  • Thu, Aug 2 2018 2:13 PM In reply to
    • gaspar
    • Montreal, Quebec
    • Posts 106
    • Points 1,325
    Just ran across this today for the first time.
    Gigabyte X58A-UD7, Core i7 920, 24G GSKill Ram, Quadro FX 1800, 2XDell U2410, Win 7 64bit with MC8.9.1 [view my complete system specs]
  • Thu, Aug 30 2018 7:05 PM In reply to
    BUMP THIS THREAD
    WHAT IS THE SOLUTION AVID?
  • Thu, Nov 28 2019 7:32 PM In reply to
    I get this when adding a Dissolve effect 9 times out of 10.
    the effect works fine after clicking OK ON THE WARNING.
    AVID SUPPORT?
    SYSTEM 1:ASUS P6X58D Premium iX58 Socket 1366 Intel I7 930 2.8GHZ 1366 Corsair 12GB (6x2GB) DDR3 1600MHz XMS3 Memory Coolermaster HAF922 Windowed... [view my complete system specs]
