Latest post Fri, Mar 2 2018 1:26 AM by touviere7. 4 replies.
  • Thu, Mar 1 2018 6:35 PM
    • touviere7
    • Joined on Mon, Mar 15 2010
    • los angeles
    • Posts 591
    • Points 6,695
    did we lose mask margin fonction in 2018.2?
    could someone confirm (or not) that in version 2018.2, we lost the fonction mask margin in the format tab?
    i did try with a new user set-up as well...no luck!
    symphony 2018.12.1 - win 10 pro64 v.1803 - QT essential 7.7.9 - nVidia gtx1080 OC (411.63) - intel i7 6800k@4.1ghz water cooled by corsair H100i V2 - MSI... [view my complete system specs]
  • Thu, Mar 1 2018 8:36 PM In reply to
    • jdrouette
    • Vancouver, Canada
    • Posts 365
    • Points 4,770
    Re: did we lose mask margin fonction in 2018.2?
    Strange. It's definitely still available on the Mac version of 2018.2, so I assume it should be there in Windows as well.
    Avid Media Composer 2018.12.1 Symphony option, Avid Artist DNxID on macOS 10.14.2, iMac Pro (2017) 10-Core, 3.0GHz Intel Xeon W, Turbo Boost up to 4.5GHz... [view my complete system specs]
  • Thu, Mar 1 2018 10:36 PM In reply to
    • touviere7
    • los angeles
    • Posts 591
    • Points 6,695
    thanks jdrouette,
    let me just be a little more specific:
    it shows as an option, but, here, it does not work - nada!Confused
  • Fri, Mar 2 2018 12:07 AM In reply to
    Have you right clicked on the Source or Record window and selected Target Mask then Mask type?
    Works like that here W10 MC 2018.2. I believe with this version you can burn the mask into your export. (from F1 help)
  • Fri, Mar 2 2018 1:26 AM In reply to
    • touviere7
    • los angeles
    • Posts 591
    • Points 6,695
    bingo! thanks andrew!
    i never needed to do that before, however i was always able to choose (or not) to burn it in when exporting a file.
    cool Yes
