Latest post Wed, Mar 7 2018 9:24 PM by Lukas Boeck. 6 replies.
Page 1 of 1 (7 items)
  • Tue, Feb 27 2018 7:49 AM
    • ADG
    • Joined on Wed, Feb 14 2018
    • Posts 7
    • Points 135
    Volume Control for Audio Monitors
    Hello,
    I have a pair of KRK Rokit 5 audio monitors that I use with Media Composer.
    The volume can only be adjusted on the back of the speakers and I was wondering if there is a volume controller I can purchase to control the level of the speakers (not my project volume) without having to reach behind the speakers.
    Kind Regards
  • Tue, Feb 27 2018 2:39 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,545
    • Points 45,565
    Re: Volume Control for Audio Monitors
    Depends on your hookup. If using the balanced inputs, I'd suggest the Behringer Monitor1. It's a minimal passive control with a mute button. If using the RCA input, there are loads of volume control out there. Just be careful of the cheap ones.
    Dave S.
  • Tue, Feb 27 2018 4:26 PM In reply to
    Or TC Level Pilot or Mackie Big Knob or its smaller version, or any of the boxes from SPL, or a (HT) preamp or a desktop mixer.
  • Tue, Feb 27 2018 7:33 PM In reply to
    • ramz434
    • Long Island
    • Posts 194
    • Points 2,435
    yeah - a Macke Mix5 would be perfect for that for under $50. Tiny little desktop mixer. The Mix8 - with 8 inputs - is only $75.
    - HP Z400/24gb ram/Windows 10/MC8.9.4/256gb Samsung SSD/ NVidia GTX 1080/HP ZR22 Monitors/ - Macbook Pro/16gb ram/OS 10.13/MC8.9.4/NVIDIA GeForce... [view my complete system specs]
  • Sat, Mar 3 2018 10:56 PM In reply to
    • Lukas Boeck
    • Joined on Fri, Jul 31 2015
    • Austria
    • Posts 469
    • Points 5,550
    TC Level Pilotis the best sounding suggestion thus far.
    palmer monicon is even better & more reliable because & while exposing more cables.
    MC 8.4.4 Cusom bulid Supermicro X9SRL-F, 32 Gig Ram, 3ware 9750 6x6TB Seagate EC Drives, LSI 9207 + LTO-6, Mojo DX, Artist Color, Flanders CM240, GTX 1070... [view my complete system specs]
  • Tue, Mar 6 2018 11:38 PM In reply to
    • ADG
    • Posts 7
    • Points 135
    How would I connect the TC Level Pilot to my system?
    Basically I have the usual audio 3.5mm jack out of my computer from there the signal splits into 2 1/4 jacks that go into each audio monitor.
    I know that the TC Level Pilot has 2x XLR (male) and 2x XLR (female).
    Just not sure how to connect it.
    Also does anyone experience crackling when turning the audio level knob on the TC Level pilot? A few people at work use them and they make quite a bit of crackling noise.
  • Wed, Mar 7 2018 9:24 PM In reply to
    • Lukas Boeck
    • Austria
    • Posts 469
    • Points 5,550
    in the wonderful world of analog audio you can connect everything to anything with adapters.
    adapter cables in your case, for convenience.
    3.5mm jack to 2x XLR Male
    2x XLR Female to 1/4 jacks
    And yes, this type of device has a tendency to crackle, independent of price, as i found out the hard way ;)
    I've got 2 of those Palmers i mentioned that don't.
